It is currently Thu Jul 03, 2025 7:32 am
PostPosted: Mon Aug 10, 2020 11:03 pm
Hey all,
I’m looking for some help on putting my oil filter canister back together as it was missing a few parts and needed a clean.
This is on a 1969 Mini Morris K 1100
I’ve never seen this cartridge filter unit before and it’s not the same as in my workshop manual.
I need to know the order of the washers , spring and seals .
I’m not sure where the extra round oring goes that was in the filter AYG65 kit.
The larger one goes is the sealing ring and the flat oring is for the base of the element .
I’m not sure where the third oring goes as I was missing a few originally.
I’ll take a pic of what I have
PostPosted: Mon Aug 10, 2020 11:35 pm
pos7box wrote:
Hey all,
Does this help?
PostPosted: Tue Aug 11, 2020 8:38 am
Thanks very much gtogreen1969,
I managed to figure it out with your images , much appreciated.
PostPosted: Tue Aug 11, 2020 1:59 pm
Adding to gtogreen1969 comments, the mini K used an Australian Ryco housing and filter that didn't use that separate base plate for the element that was common to most UK made filter units and is shown in many workshop manuals.
The Ryco filter element is p/n R2200P (P for paper) and the base plate is built into each element.
