It is currently Sat Jul 05, 2025 5:54 am
 Post subject: early 850 clutch
PostPosted: Sun Jun 07, 2020 1:40 pm
Hi I have an early 850 with the coil type clutch.
Is the procedure for adjusting the overthrow clutch the same as the more modern clutches? I.e. pedal pushed in, adjust nut up to the face of the wok, turn in one more flat then lock with the second nut?
Thanks!
Rob
Present
'71&'76 Clubman minis
1961 Austin Se7en
 Post subject: Re: early 850 clutch
PostPosted: Sun Jun 07, 2020 1:45 pm
Yes it’s the same.
Users browsing this forum: Bing [Bot], drmini in aust and 89 guests
