VSP580P vs AEA525 valve springs? https://ausmini.com/forums/viewtopic.php?f=2&t=100060 |
Author: | TartanRed [ Tue Jun 02, 2020 9:09 pm ] |
Post subject: | VSP580P vs AEA525 valve springs? |
I have a warm 1150 motor running a worked 202 head and Camtech 619. It currently has single valve springs and the seat pressures are apparently a bit on the low side. I ordered a set of VSP580P valve springs, but instead was supplied a set of Minispares C-AEA525 springs. Can anyone advise the difference in poundage, coil bind height between the two springs? I think the head has valve stems long enough to allow use of the AEA-525 springs, and the springs look pretty good, but I am a bit wary that the seat pressure could end up too high if I can't get the fitted height as recommended. |
