It is currently Sun Jul 06, 2025 10:24 am
 Post subject: Rear Rotisserie Cover
PostPosted: Fri May 29, 2020 4:04 pm
What colour was the boot side of the rear rotisserie cover?
In my spares, I have one that has been sprayed body colour, one that is a silver / grey, or were they left unpainted from the factory?
This is for an early / mid 60’s Aussie mini.
Thanks in advance
PostPosted: Fri May 29, 2020 4:47 pm
The cover, clips and screws were all fitted after the body was painted. The cover was grey/silver as you suggest and sealed to the body with a mastic strip about 15-20mm wide. The srews used here were unique to this location and featured a wider than normal pan head style self taper.
PostPosted: Fri May 29, 2020 5:48 pm
Not my 64. Unpainted and no mastic.
