It is currently Fri Jul 18, 2025 1:17 am
 Post subject: SU tags
PostPosted: Mon May 18, 2020 11:40 pm
I followed with interest the wanted post from bubbacluby regarding his search for some SU carb ID tags. I actually thought I may have been able to help him out. Sorry mate no luck. The L&R pair I have will most likely go on my set.
Saying that, I have no idea what they are off. They were simply in a box of SU parts.
Is there a list or the like that tells what they are off or can somebody tell me what they are.
Ian
Sent from my SM-G965F using Tapatalk
1965 Smooth roof Van
1969 Cooper S MK2
1970 Mini K
 Post subject: Re: SU tags
PostPosted: Tue May 19, 2020 12:19 am
Thanks anyway, nearly got there
Sent from my SM-N960F using Tapatalk
PostPosted: Tue May 19, 2020 6:31 am
Ian
As just one example from your collection:
http://sucarb.co.uk/carbspec/carburetto ... s/id/1907/
PostPosted: Tue May 19, 2020 6:47 am
There’s also some helpful spec sheets here
http://www.oldengine.org/members/diesel ... bMenu4.htm
PostPosted: Tue May 19, 2020 8:31 am
Thanks DavidE and timmy201 for the info re spec sheets.
Very helpful :)
I'm still looking for AUD 146L and AUD 146R if anybody can help.
PostPosted: Tue May 19, 2020 8:49 am
Very helpful :)
http://sucarb.co.uk/carbspec/carburetto ... s/id/1721/
PostPosted: Tue May 19, 2020 10:07 am
He’s after the tags themselves, not the spec :)
PostPosted: Tue May 19, 2020 7:01 pm
Correct I am.
Would prefer to have original tags
Even if I could find just the AUD 146R Tag only.
PostPosted: Sun May 24, 2020 12:37 pm
The AUD146 L and R tags are off a Cooper S 1964 to 1970 1275cc HS2 Carburettor
The AUD 13 is off a Morris 1100 1967 t0 1972 HS2 Carb single
The AUD86 is off a Mini MK2 998 1967 to 1968 single carb
The AUD 291 Is off an Austin 1800 Mk2 1968 t0 1970 used an HS6 carb
Mk1 Cooper S
Mini K Rally car
