cooperess wrote:
1071 S I'm with you after the checks I have tried. If the short is in my new wiring loom after the numerous times I have heated it up, then all the tape needs to be removed or is there a simpler way?
Generally I would say if things don't get hot enough to let some smoke out then you won't have done any damage.
It's unlikely that your new loom (in itself) has a short.... You should be looking for un-insulated connectors or incorrect connections (an earth wire that shouldn't be there) or maybe wrong or multiple wires from a single terminal.
Car and especially Mini electrics are really quite simple. Power flows from the + battery terminal to somewhere (ie (usually but not always) the fuse box to somewhere (ignition switch maybe) to (usually but not always) a switch to something (lights, parkers, ignition) to earth (something bolted to the body) thence to the battery negative terminal (through an earth strap). Each item has its own circuit ... OK, some things (like headlights (unless you feed them through relays) and tail lights) may live on a single circuit.
The correct wiring diagram shows how each circuit is connected. All
you have to do is check that the wires in your car match the diagram.
Because my cars are old, and have lots of non-standard fittings ...and wires...(stereo, extra lights, kill switches etc etc), I'm not a fan of wrapped looms. Small cable ties keep everything neat. If you must use wrap use cable wrapping which is non-adhesive... Do NOT use standard insulating/electricians tape.
You are correct, other people (me) run high powered lights (130W high beams) ...and spots...without any issues...
Cheers, Ian
