It is currently Sat Aug 23, 2025 2:31 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 546, 547, 548, 549, 550, 551, 552 ... 568  Next
PostPosted: Tue Nov 22, 2016 5:55 pm
Disconnected the optional Accuspark `Missile switch' and bypass loom from the black box. Not needed with a Lucas starter. :)
What's the missile switch?
As I have the Lucus starter
1968 Morris Mini Cooper S
PostPosted: Tue Nov 22, 2016 9:06 pm
PM sent. ;)
PostPosted: Wed Nov 23, 2016 1:54 pm
Thanks DR
The other day driving to work I stalled it and the only way to get it going was to clutch start (turn the key and nothing)
So in the garage today I started playing around and same deal Turn the key nothing
Did a bit of hunting shorted out the new solinoid and bang all good
Swapped out the new with the old and perfect
Moral of the story if it ain't broke don't fix it
Just because it's shiny doesn't mean it works
PostPosted: Mon Nov 28, 2016 9:30 pm
Bled the clutch again, deefinately need to grab a slave seal spreader
Ran out of fuel on the way out for tea, lucky it was at the top of the hill on the way out and could roll all the way back home for a top up
PostPosted: Tue Nov 29, 2016 11:11 am
I put a cup spreader in the other day without disconnecting the hose, and it has helped heaps. ps I haven't even bled the clutch and it all works a lot better than before.
Sometimes when I turn the ignition key I get nothing so I open the bonnet and press the starter button on the solenoid whilst the ignition is off and then I can start the car with the key no problems.
Does this mean my starter motor has a problem more likely than the solenoid.
happy motoring
PostPosted: Tue Nov 29, 2016 11:33 am
Sounds like dodgy solenoid if it operates manually but not electrically, the relay inside is not doing it's job...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Tue Nov 29, 2016 4:22 pm
Well...he did say he shorted it...so that means to "work" (he bypassed both the contact breakers and the solenoid circuit)...
PostPosted: Tue Nov 29, 2016 6:35 pm
Yeap dead solenoid I say
PostPosted: Mon Dec 19, 2016 12:33 am
Spent 12 hours making a set of Cobra Classic seats on mini specific frames fit in the car at a height that doesn't require an open sunroof... Now over 2" lower than as the frames come, and the slider almost touches the seat crossmember.
Are they all this much of a pain or do people just put up with the Moke-like driving position :?
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Mon Dec 19, 2016 8:41 pm
Had similar problems with genuine frames for Cobra seats. Ended up remaking the frames to have the rear of each seat sit further back and to include height adjustment and backrake angle.
Still have to remove seats from car to adjust seats forward/backward.
PostPosted: Mon Dec 19, 2016 8:51 pm
I managed to keep the sliders, but had to cut down and re drill the front brackets as well as cutting down the seat frame. The next big rebuild may see the seat cross member 'revised' to gain a bit more height...
*witty signature*
PostPosted: Thu Dec 22, 2016 8:23 pm
Put 2 new Yoko A008s (Bob Jane, $138 ea, f&b) on the front for traction and the 10 year oldies are now on back.
The 2 geriatric 20 yo ones are now destined for Aaron's khana car. :D
PostPosted: Thu Dec 29, 2016 8:57 pm
Fitted new pot joints and disc brakes - only taken 3 and a bit years since buying them and done in a day.
https://www.facebook.com/photo.php?fbid=10154232673901724&set=a.10154232673486724.1073741843.594006723&type=3&size=750%2C1000
https://www.facebook.com/photo.php?fbid=10154232673806724&set=a.10154232673486724.1073741843.594006723&type=3&size=640%2C480
https://www.facebook.com/photo.php?fbid=10154232674071724&set=a.10154232673486724.1073741843.594006723&type=3&size=640%2C480
PostPosted: Fri Dec 30, 2016 6:32 pm
Got some new switches as a Christmas pressy so i made a new switch panel for them today from some Jarrah floorboards
PostPosted: Fri Dec 30, 2016 8:25 pm
Attached two bottom steady bars on either side of the engine - one new requiring a hole to be drilled in the sub-frame the other an old one I disconnected to remove the pot joint to the go with the disc brakes - found the rubber bushes had perished and crystalized and fell apart - bummer.
Users browsing this forum: Bing [Bot] and 260 guests
