It is currently Sun Aug 24, 2025 2:03 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 530, 531, 532, 533, 534, 535, 536 ... 568  Next
PostPosted: Sun Mar 13, 2016 12:55 pm
In the moke
Been running crook for about 2weeks. Changed the condensor and points and running fine again. Changed the oil and filter wile I was at it.
PostPosted: Sun Mar 13, 2016 7:19 pm
After having rebuilt my S engine over 2 years ago, I thought it was about time I ran the engine on the bench. As expected runs like a clock. Now ready for new lightweight flywheel and back plate to be installed. Another job done.
PostPosted: Mon Mar 14, 2016 8:53 pm
Drove it for the 1st time! Just up and down the garage to being and then once aroumd the court. Just got me keen to get it on the road properly. The sad bit is I'm about to put it in storage while we build our house.
PostPosted: Mon Mar 14, 2016 10:34 pm
I hear you on that one.
PostPosted: Tue Mar 15, 2016 9:11 pm
Brake pedal was a bit low :|
Adjusted the rear drums.
Brake pedal is back to normal :D
Handbrake works better :D
Who'd of thought it :lol:
PostPosted: Sat Mar 19, 2016 3:25 pm
Changed the oil out and gave her a once over for another run down to Sydney tomorrow. Also attached some new plates.
The Lockheed booster is losing a bit of fluid through the air valve...might be time to take her apart for a new seal!
PostPosted: Sat Mar 19, 2016 3:57 pm
Ah yes, but which one to fit? So many to choose from. :shock:
PostPosted: Sat Mar 19, 2016 5:09 pm
I took Mrs timmy201 and the dog out for a drive. I pulled out the passenger seat to fit us all in :D The dog wasn't impressed at the volume of the mini...
PostPosted: Sat Mar 19, 2016 7:04 pm
Took wiper wheel boxes out. Ordered new ones due to the stripped threads for the retaining nuts and broken cog.
PostPosted: Sat Mar 19, 2016 7:07 pm
Great image :)
PostPosted: Sat Mar 19, 2016 8:45 pm
Drove it for the second tme today which was great, apart from the fact I was putting it in storage until our new house is built
PostPosted: Sat Mar 19, 2016 10:00 pm
Got the fuel tanks back in and got the driver side adjustable lower arm in. Tomorrow's job is passenger side adjustable lower arm and new cone. Then I can move onto some less difficult tasks.
PostPosted: Sun Mar 20, 2016 7:03 am
Fitted a geMini starter. :)
I now need to turn the dizzy 90deg to allow the cap's lower clip to be removed easily.
PostPosted: Sun Mar 20, 2016 9:28 am
Pulled the Lockheed booster down and changed out a problem reaction piston seal.
PostPosted: Sun Mar 20, 2016 6:22 pm
After finishing up putting in new cones and adjusting the front passenger side hi lo (also involving losing the Allen key and socket in the adjuster hole for an hour) I moved onto the painful task of removing the previous owners overly fabricated front seat mounts from the floor and seat channel.
Photos below. Passenger side done. Driver side yet to be done.
