It is currently Sun Jul 20, 2025 3:42 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 445, 446, 447, 448, 449, 450, 451 ... 568  Next
PostPosted: Wed Mar 05, 2014 7:04 pm
Adjusted the floats on my carbys so they actually worked.
Did a compression test all good!
I borrowed a mates timing light to check the timing after setting it statically turns out I had it way to far retarded, adjusted it dynamically to about 7-8 and now my mini has come to LIFE for the first time since!
So pumped!
PostPosted: Wed Mar 05, 2014 9:16 pm
kiwiinwgtn wrote:
Made a bush copy of service tool 18G581, for pulling idler bearing out.
No more MIG welding a bolt into them, yippee!! :P
Hi kev
do post a picture
Bernard
Abso-flippin-lutely! I've just made my second Ausmini tool and I'm looking at expanding the collection.
Tonight I also made the first motion shaft bearing puller (instructed by the bloke above) and it works great. Pulled the bearing off easily.
Behold! The mighty 850!
PostPosted: Wed Mar 05, 2014 11:15 pm
Read about brake adjustment.
I will tackle the brakes today
1967 Mini Deluxe 1275 heaps of modifications
1969 Mini Matic 1100
PostPosted: Thu Mar 06, 2014 7:27 am
Hi kev
do post a picture
Bernard
I will take pics today and put them in a separate thread here.
I have no drawing, but I'll give dimensions and machining steps.
[edit] Now done, it's in the how-to forum. See link on this page ^^
PostPosted: Thu Mar 06, 2014 5:45 pm
Well done Kev
Luv your use of the drive shaft yoke
Kiwiinwgtn
[edit] Now done, it's in the how-to forum. See link on this page ^^[/quote]
PostPosted: Thu Mar 06, 2014 8:49 pm
Adjusted the Brakes, now have a better pedal feel, a better handbrake and the matic even stops.
PostPosted: Thu Mar 06, 2014 8:57 pm
kiwiinwgtn wrote:
Well done Kev
Kiwiinwgtn
[/quote]
I couldn't see this link anywhere on this page?
But I did skip across to the How To section and found it easy. Nice one, drmini.
PostPosted: Thu Mar 06, 2014 9:05 pm
This is link title I referred to, is on p1 of chat at present..
"Moved: Bush version of 18G581 idler gear removal tool"
PostPosted: Thu Mar 06, 2014 11:24 pm
Okay.
I did spend twenty minutes after work trying to remove the two detent plungers for the selector rods. They wouldn't fall past the threads no matter what I tried. Even compressed air wouldn't blow them out (naughty). Tomorrow I try the 'suck-out-your-fillings' magnet I have at home.
If I can manage to peel it off the side of the toolbox!
PostPosted: Fri Mar 07, 2014 6:58 am
Sometimes they sludge up in there and get stuck.
Get some coat hanger wire and bend it 90deg to a hook. Spray degreaser or WD40 in there, then work the plunger to and for with the hook inside and a screwdriver outside....
PostPosted: Fri Mar 07, 2014 8:35 am
Hot tip! Thanks.
PostPosted: Fri Mar 07, 2014 8:30 pm
Find Sugar up with Petrol. I have done 155 miles since the auto transmission rebuild. Did 119 miles with one tank (22.06 litres) 4.98 gallons therefore 23.89 miles.
What sort of fuel consumption are other minis and mini matins getting?
Also tidied up the garage so Sugar has her own parking spot and remote control garbage door.
PostPosted: Fri Mar 07, 2014 9:07 pm
Just sent off a list of part I want to Karcraft, since getting it started it has got the fire burning in the belly strongly!
PostPosted: Sat Mar 08, 2014 2:02 pm
Washed it and took it to Hawksnest Motorfest. Good turn out of minis and good to see a mini won Presidents choice award. Met up with local Mini friends. Also met ausmini member BBY775 and a couple of Mini car club members from Sydney.
PostPosted: Sat Mar 08, 2014 7:46 pm
more than nothing!!!
the reconditioned bottom end and gearbox have been sitting on my bench since April last year
the reconditioned head has been sitting on top of that since September
the rebushed rockers have been sitting on that since November
today I torqued nuts up!!
