It is currently Sun Aug 24, 2025 4:17 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 36, 37, 38, 39, 40, 41, 42 ... 568  Next
PostPosted: Wed Jun 03, 2009 12:46 pm
Replaced the 2 tiny copper rivets that hold the radiator front side on, with a couple of very short M3 screws, nuts and Loctite.
Looks OK and is probably stronger.
Can't seem to buy these rivets anywhere around here anyway.
PostPosted: Wed Jun 03, 2009 3:00 pm
Finished re wiring the backend of Marcia. I knew the fuel pump wire had fused and it was all the way. So I ran a new wire all along and wraped some of that wire cover all along the loom. All other wires are good. Had to pull the passenger side roof lining down thou :roll:
PostPosted: Wed Jun 03, 2009 6:00 pm
took off the Drums, bled the brakes and have had the master Cylinder apart to try and find why the brakes are so... bad.
now know i need new front drums and that the Master Cylinder has rust inside it ??? :?
PostPosted: Wed Jun 03, 2009 11:20 pm
sounds like you're on the right track to getting the brakes working the way they're supposed to - when all the parts are in good condition, drums work well
tonight I removed my distributor and put a blanking plate over the hole in the block (left the drive in there for now), also fitted some different air filters on some intakes I made, and changed the oil :)
PostPosted: Wed Jun 03, 2009 11:36 pm
This space for rent
Since I fitted the 88*C thermostat the K has been boiling after only a few K's, so pulled it out and stuck it on the stove with a thermometer. Turns out it doesn't start to open until about 91*C.. that's a bit hot, methinks. Back to the 82*C item...
Also while I was in there yanked the old water pump off (pressed steel impeller variety) as I have a new high-volume cast impeller item ready to go on. After 8 years on the car the old impeller was in surprisingly good shape, very little corrosion evident. Most surprised, although I do run glycol coolant pretty religiously so that's probably helped.
Now have to put it all back together again..
PostPosted: Thu Jun 04, 2009 11:09 am
Spent more money on it, this time a genuine 60s Moto-lita steering wheel. It will need a bit of restoring.
Lindsay Palmer
06 Mazda SP23
80 Alfa GTV (weekend toy)
86 626 Turbo (daily drive, now stolen)
71 cooper s replica
69 cooper replica
76 clubman
62 english 850
68 Mini Auto
PostPosted: Thu Jun 04, 2009 5:43 pm
The TIG
Did some work on my custom steering column in the Travelle"R".
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Thu Jun 04, 2009 7:18 pm
Spent the morning machining a bunch of (usually unobtainium) late Oz type wiper shaft escutcheons for Mini King.
These are those rubber/plastic thingys on top of the body where the wiper arms go on. :wink:
PostPosted: Thu Jun 04, 2009 8:32 pm
Had my radiator re-cored.
PostPosted: Thu Jun 04, 2009 8:41 pm
Started stripping all the kakky paint off and welded in a patch panel for the a panel rust BUT ran out ov mig wire.... BUGGA :evil:
Hi Ho Hi Ho its off to the mig shop i go :lol: :lol:
PostPosted: Thu Jun 04, 2009 9:06 pm
After a long time in storage, i got my 61 850 out and gave it a clean and its now finally under cover. Considering its been outside for the last 8 years i think the original paint isnt too bad.
Have a Nice Day.
PostPosted: Thu Jun 04, 2009 11:36 pm
This space for rent
Put the K back together after yesterday's dismantling effort.
  • Fitted the new cast-impeller water pump, and a new fan belt.
  • Refitted the radiator and left the 88*C thermostat in, in the hope the high-flow pump solves my boiling problem.
  • Fitted brand new thermostat housing studs to replace the cruddy Zenith bolts which were in there.
  • Cut a new set of gaskets and fitted them with a bit of Permatex sealant. I must be getting good at this, the whole thing sealed perfectly on the first attempt :lol:
  • Dropped the oil and replaced with a fresh slug of KMX. What came out appears to be doing a fair job of turning back into coal, but then it's been probably 2000mi since the last change.
  • Warmed it up and waited with kitchen thermometer in hand for the thermostat to open, so I could measure the radiator temp. And waited. And waited. And gave up waiting, and took it for a fang instead. On return, the coolant measured almost exactly 88*C :D Happy with that, now maybe the oil will stay clean a little bit longer.
PostPosted: Thu Jun 04, 2009 11:37 pm
Blew it up :-)
PostPosted: Thu Jun 04, 2009 11:55 pm
This space for rent
TheMiniMan wrote:
Blew it up :-)
Yeah, but you finally did something to it :lol: :lol:
PostPosted: Fri Jun 05, 2009 7:02 am
:D Cool :!:
:P Now fix it and get it on the road :!: :wink: :lol:
Users browsing this forum: Bing [Bot] and 236 guests
