It is currently Fri Aug 01, 2025 12:35 pm
Post new topic Reply to topic  [ 122 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 9  Next
 Post subject: Re: Car trailers
PostPosted: Wed Aug 20, 2014 5:20 pm
gtogreen1969 wrote:
It is looks a bit heavier than I was after but certainly could be worth a look , wonder why it didn't come up on the searches I did?
edit - it does come up as a homemade trailer when I did a rego check so I will need to have a good look
PostPosted: Wed Aug 20, 2014 7:35 pm
Unless it was made by a big company it will have home made on the VIN. The last 2 trailers I purchased were built by smaller companies and were engraved as home made. I have an 8x5 single axle box trailer at the moment and will be upgrading to a more mini friendly trailer soon. Not sure what style.
PostPosted: Thu Aug 21, 2014 12:39 pm
Sad to say that one turned out to be a bust. Definitely homemade, supposedly in 2013 and the rust is bubbling the paintwork off all over and plenty more underneath :roll: needs a complete strip down and repaint if you wanted to keep it long term.
PostPosted: Thu Aug 21, 2014 4:08 pm
When do you need it by?
PostPosted: Thu Aug 21, 2014 8:54 pm
Ok guys, been hunting around the web and the sales yards and I think I have a fair idea of which way I am headed. The tilt trailers look to be a very interesting option however they come at a hefty price which if i was going to use it frequently a new one would be easily justified, given that I am going to be a infrequent user I am going to stick with a traditional design to save some coin (if there was such a thing as a decent second hand trailer it would have been an option but to be honest everything I looked at was trash).
I am looking at a variation of the trailer pictured below:
12x6 floor center 1/3 removed to reduce weight
Wheel arches lowered to a max height of 150mm aiming for 100mm above the deck
12" rims with light truck tyres
Front mounted tool box
reinforced skids on tail
I am expecting this to be low at the rear as it is but one thing that I have considered is whether to add a 100mm drop beaver tail to the rear? What are your thoughts? Should it have a sufficient approach angle (1800 ramps) or would it be best to add the beaver tail? The only other thing I was considering was trying to move the spare from the draw bar to maybe a vertical mount on the front left?
PostPosted: Thu Aug 21, 2014 10:42 pm
Hi, have you thought of the guards being axle mounted? That would reduce the high of them heaps as the clearance would be minimal.
I wouldn't worry about a beaver tail as you are more likely to get hooked up somewhere (driveways, fuel stops etc). If ramp angle is close you can always use the jockey wheel a bit to angle the trailer better.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Thu Aug 21, 2014 10:56 pm
Hi Womble99,
Everyone on here will have their own opinion of what's right and wrong for a car trailer, and the rest is up to you mate.
I was lucky enough to start off racing with a excellent tilt trailer custom made for a mini, and have enjoyed the benefits of compact, lightweight and absolute ease of use. I have also in the past owned a larger tandem axle race trailer with beaver tail, spare wheel carrier, fuel carriers, toolboxes and all the gear. If you are ONLY specifically towing a mini a big trailer like in the photo you provided is overkill, too big, and too heavy, the initial purchase cost of a used quality single axle tilt trailer could be higher than a cheap nasty heavy trailer, the future benefits in costs and connivence are as follows.
Less wear and drag on the tow vehicle - better acceleration and braking (safety and fuel usage)
Cheaper registration for lighter weight carrying trailers (in NSW anyway)
No pinch point damage the underside of the mini exhausts etc, and winding jockey wheels for improved approach angle
No ramps
Smaller for storage
Easy to move around and hitch on the tow bar
As mentioned earlier much easier to manoeuvre on narrow roads
If it's a smaller trailer you are less frequently requested as a towing service.
As it is an expensive purchase I would wait for something to come up similar to what Coatsie purchased, which seems like good value, I think anything under $2000 will normally need some work.
Just my 2c mate and good luck.
Chris
PostPosted: Fri Aug 22, 2014 8:59 am
If your after a more general purpose trailer that can be used for a mini, maybe consider a custom 7 x 5 box trailer.
I made one so that the front folded down flat (only to clear the front,wheels were still in the tray) and the rear tail board folded down to a beaver tail which the rear wheels sat on, it was sprung with 14" wheels, ramps were only about 1m long and I could still load my old race car with a bit of extra angle from the jockey wheel.
I will try and find a pic if you want? sold it to a mate now as I needed a bigger trailer for the wife's torana.
PostPosted: Fri Aug 22, 2014 10:41 am
That's ok Greg, I already have a 7x5 trailer for general purpose stuff. I wanted to go to a proper trailer where I don't have to exercise the ultimate care trying to load my car each time into a space barely big enough and risk damage.
I know the traditional design looks to be over kill and I agree it is, however if there was a reasonable second hand market in Adelaide which there doesn't seem to be one I would wait but then how long do you wait?
Down here I could get one of the backyard bandits to build this for about $2500 and it would be a piece of crap. I have seen lots of those around this last week. I have been talking with the company who built my last trailer they have been through each option I have found and provided quotes to build. Yes they suggest a standard 8x5 trailer as the cheapest option. However they were happy to work with me to see what could be done to modify the drift car trailer version to suit a mini, end result they believe the smaller version will come in under 400kg which for a tandem is pretty good.
Is it the perfect trailer, no, I know that but I can't justify nearly an extra $2000 for a tilta which seems to be pretty good or the $5000 for the fully hydraulic one I found in towoomba which was sweet. :smile:
PostPosted: Fri Aug 22, 2014 5:54 pm
My trailer is 3000 x 1500 inside and is multi use. The mini fits on easy but can't open doors however that's no big deal I just climb in the window. To wind window up and down I leave the 1/4 vent
unlocked. Trailer is galvanized and single axle.
PostPosted: Fri Aug 22, 2014 11:02 pm
Too big for a mini really but these trailers are worth a look if you like the Neva type but don't have $$$
http://www.loadsafetrailers.com
Made in Brisbane by a crusty old engineer with too many cars.
M
 Post subject: Car trailers
PostPosted: Sat Aug 23, 2014 6:44 pm
This is my trailer that I built , yes it's tandem but it tows like a dream it has hydraulic disk brakes and a 3000kg load rating ... It weighs in at 420kgs .. It's a simple thing with alloy ramps and a electric winch
I'm currently building another trailer for a fellow mini addict , which will be single axle with springs and should be under 250kgs once completed
If you are interested in having one custom built , drop me a PM
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Sun Aug 24, 2014 5:08 pm
^ indeed a good example of a nice trailer. The wheel straps are an absolute breeze, too; as are the ramps which locate alongside the guards.
PostPosted: Sun Aug 24, 2014 5:34 pm
I was looking at the wheel straps, it looks like the fastening points were added after the middle photo were taken? It certainly does look very neat and I have sent Beanie a PM.
PostPosted: Sun Aug 24, 2014 5:53 pm
You can see the retractable hook part in the middle image, but the wheel chock was added after (removable) once the perfect balance spot was achieved - Beanie can confirm!
