It is currently Fri Jul 25, 2025 9:30 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Dec 02, 2016 12:42 pm
I thought that was a problem, there were no insructions?
PostPosted: Fri Dec 02, 2016 2:49 pm
I'm really keen to get a black box into my mini, but have a couple of hesitations, mostly based on my limited knowledge of timing and advance curves, etc. I want to have more consistent spark, reliability and more control over it all, but I understand very little of how it all works lol
Also, I'm running a 1500cc ohc motor in my mini, so I'm not sure I would be able to transfer peoples inputs using A series engines over to my application very accurately.
Also, convertible mini, whats the cost on a kit anyway?
PostPosted: Fri Dec 02, 2016 4:56 pm
I had that problem
Got the kit with no instructions or the lock wire to lock the advance arms on the dizzy
Dr Mini helped me out with a set of instructions
1970 MK2 Cooper S
PostPosted: Fri Dec 02, 2016 7:52 pm
I got the instructions but no lock wire...
What is the most suitable lock wire to use?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Fri Dec 02, 2016 9:27 pm
UK boxes were supplied with 0.6mm SS welding wire. I have used 0.8 on others (because I have a MIG spool of it).
PostPosted: Fri Dec 02, 2016 10:13 pm
I might redo mine then, all I had to hand was fairly soft iron tie wire..
67 Deluxe
Dry suspension
PostPosted: Sat Dec 03, 2016 6:08 am
I went to a motorcycle shop and they sold me a little packet of Aviation lock wire
Its used to tie up handlebar grips on motorcycles when they come loose
1970 MK2 Cooper S
PostPosted: Sat Dec 03, 2016 6:24 am
Don't bother, it will be fine as is.
Plenty strong enough. :wink:
PostPosted: Sun Dec 04, 2016 8:54 am
Unfortunately the Manufacturer of the Stealth Box does not supply the lock wire. They do not want to take the responsibility of things going wrong in that process. Which is fair enough. There are various ways people prefer to use for locking the advance weights. Other news is I have asked them to change the program Disc to Windows 10 and they are going to do it.
"Let us remove your "SHORTS"
PostPosted: Sun Dec 04, 2016 9:07 am
Tony,
If the manufacturer does the change of the program disc to Windows 10, do you know if it will be available so everyone can download it and upgrade from the original XP / Windows 7 disc supplied?
Cheers Shane
PostPosted: Sun Dec 04, 2016 6:56 pm
It will be supplied as a disc as before with new units sold.
PostPosted: Thu Dec 08, 2016 6:41 am
Hello,
I'm over here in the states, but would be interested in acquiring a black box for my long suffering Elf project (it's been apart for quite some time! :D )
Questions: Does the exe really come on a floppy? Is there somewhere (or someone) who can email it, or possibly post to a dropbox? I'm not entirely certain I could find a floppy drive....
Also, can this be used with vac advance?
I'm pretty new to the whole Ignition curve game, but this looks like a good way to get started!
Daniel
My Mini --> 1966 Riley Elf (currently in pieces!)
PostPosted: Thu Dec 08, 2016 7:33 am
It comes on a CD
PostPosted: Thu Dec 08, 2016 8:20 am
Mine came on a usb stick. But box bought via Accuspark.
It's only a relatively small .exe file, could be emailed.. [edit] I did this once already.
Last edited by drmini in aust on Thu Dec 08, 2016 11:13 am, edited 1 time in total.
PostPosted: Thu Dec 08, 2016 11:03 am
Lots of new laptops have no Cd drive. I used a cd desktop to get it onto a USB stick.
