It is currently Sun Jul 27, 2025 4:51 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Crack testing
PostPosted: Wed Sep 07, 2016 3:25 pm
cool, as I said earlier I will leave regrind to whoever buys it after I get it tested. But I will get them to measure it up to see how much it is worn :-)
PostPosted: Wed Sep 07, 2016 5:08 pm
Well bad news, mine has several cracks, and I'm out of pocket for the test. But at least we didn't put it in a rebuilt motor and have it go BANG!!!
This black light fluorescent test also validated my dyecheck kit, which also showed at least 1 crack.
[edit] This is a basically a magnaflux process. The crank is magnetised and a mixture of kero + iron filings (or modern equivalent) poured over it.
Filings stand on end where a crack is detected.
Last edited by drmini in aust on Sun Sep 18, 2016 10:21 pm, edited 2 times in total.
PostPosted: Wed Sep 07, 2016 5:59 pm
That sucks, did it ring right with the ping test?
PostPosted: Wed Sep 07, 2016 7:37 pm
It wasn't consistent.
PostPosted: Thu Sep 08, 2016 6:54 am
And everyone wants things for free.
"Let us remove your "SHORTS"
PostPosted: Thu Sep 08, 2016 12:31 pm
I went and picked up my dead crank. Was cracked 1/3 of the way round #1 crankpin. Due to the previous regrind gouging the fillet radius.
St George Cranks now routinely crack tests ALL Mini cranks before grinding. Because at least half those he gets in are cracked. :cry:
[edit]
I would be wary of old 1098 cranks now, they flex and suffer from cracking much more than 998 ones do.
PostPosted: Fri Sep 16, 2016 10:51 am
I have a crank here that tested good, problem is now I'm afraid to part with it. Also have a 1098 clubman motor sitting somewhere, could be junk too!
