It is currently Sun Jul 27, 2025 11:49 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Aug 12, 2016 10:16 am
I just bought mine off John it did need slight modification ie the water bottle holes and also a trim around the wiper motor but appart from that it fit. Let's face it all the mini parts only kind of fit. They were hand built 50 years ago then modified over and over again.
1968 Morris Mini Cooper S
PostPosted: Fri Aug 12, 2016 10:51 am
This appears to be the material they use
http://www.prostitch.com.au/shopdisplay ... es&sppp=20
1970 MK2 Cooper S
PostPosted: Fri Aug 12, 2016 11:09 am
The Mini King
Hi John
Mate i appreciate your offer of a refund but i would rather if you could supply a blank piece of material and i will cut one to suit
Thanks
GundyGuy
Marc
I am processing a refund for you today. There is no need to return the offending part.
I don't hold stock of the base material.
John Smidt
PostPosted: Fri Aug 12, 2016 11:47 am
John Smidt wrote:
phillb wrote:
I have used this item also and apart from very minor alterations no problems fitting it. (Mk 1 with round body wiper motor)
I think if you were truly determined to make your own you would need to buy the vinyl and backing separately and glue it yourself.
At one stage I was considering doing this because (if you want to be really fussy) the original Australian ones from the period of my car had a finer grain in the vinyl.
Hi Philip,
You are correct when you say that the original material was different, yes it was a finer grain and was backed with
different material than anything I have been able to buy these days.
It becomes very difficult to reproduce some items, because the materials used 30 plus years ago is
is not always available now days. In some cases it can be reproduced but the cost v demand has to be considered
Yes totally understand John. Also as you know there were so many minor changes over the years in materials and minor items it would be next to impossible to cover everything. 98% of people are simply interested in an item performing the function intended rather than being an exact visual replica.
PostPosted: Fri Aug 12, 2016 12:54 pm
I will post some photos of the difference in wiper position
As i will be removing my wiper motor so i can mark out the area
I will make a template of this and send it to you if you would like me to John
1970 MK2 Cooper S
PostPosted: Fri Aug 12, 2016 2:42 pm
Here are some photos
1970 MK2 Cooper S
PostPosted: Fri Aug 12, 2016 2:54 pm
Hmm. I have a feeling you are trying to position it up too high. Remember that the slit for the hinge needs to be low enough so that the hinge arm goes down though the slit. Up too high it will jam and damage hot bonnet and hinge. The bottom edge of the blanket curves and covers the square section that runs across the firewall. Part of the idea is to help direct water over this section. The top edge normally just curves up and slips behind the front edge of the scuttle panel.
PostPosted: Fri Aug 12, 2016 2:59 pm
I guess being dropped at birth doesn't help my case
Sent from my HTC_PN071 using Tapatalk
1970 MK2 Cooper S
PostPosted: Fri Aug 12, 2016 4:13 pm
Below is the end of the original insulation blanket from my MK II S, to suit the 12AUW wiper motor. By cutting a similar shape out of the MKO item it should fit and I think would look OK for most situations. The existing recess in the mat (for a Mark 1 wiper motor) should be mostly hidden from view by the wiper motor itself. I guess it just depends on how far people are prepared to go for an original look. I know some Mini owners simply want to cut down the engine bay noise and don't want to mess around making their own so an off-the-shelf product may suit their needs.
For pure cost reasons I can understand Mini spares businesses being reluctant to have insulation mats, carpet sets, underlay, etc. tailored to every possible situation to suit the full range of Australian assembled Minis. A quick search of online stores shows Minisport SA selling one style firewall mat for all Mini models with instructions "...will fit any model mini, all you do is get to it with a knife.". You can see the style Minis Plus sell via the link earlier in this thread. MKO has its solution.
Without these organisations Australian Mini enthusiasts would be much worse off so we should support them where we can. Of course the option to go to a professional motor trimmer is always there, but you usually pay a premium for the privilege and still may not get the desired quality.
Hope this helps. :)
PostPosted: Fri Aug 12, 2016 4:52 pm
Thanks for the photo Doug. I noticed in the bottom right of the photo it is cut out a bit. Is that to go around the heater hoses?
PostPosted: Fri Aug 12, 2016 5:00 pm
That photo is great
Now i can work it out
That's why i am on this forum to get help with issues and learn some tricks about Mini's
Last mini i owned was 40 years ago when i was a school kid
1970 MK2 Cooper S
PostPosted: Fri Aug 12, 2016 5:14 pm
Yes, well spotted. I take it your left and right is from inside the car? :shock: :D
Here's a photo I took some time ago. The bit on the driver's side end has detached and is missing in this shot. Note the inclusion of a flap to access an ID plate (not used on MK II) or probably paint sticker. I haven't lined it up to confirm which.
PostPosted: Fri Aug 12, 2016 5:18 pm
Could you tell me the height of this right in the middle
1970 MK2 Cooper S
PostPosted: Fri Aug 12, 2016 5:23 pm
275 mm. Probably a bit wider originally before shrinkage over time.
PostPosted: Fri Aug 12, 2016 5:28 pm
Haha. I just noticed that i wrote right instead of left. Time to up the meds
