It is currently Mon Jul 28, 2025 1:38 am
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: At my wits end
PostPosted: Mon Jul 25, 2016 4:35 pm
Miraz wrote:
2 fuses in the fuse box or 4?
2 mate thanks!
PostPosted: Mon Jul 25, 2016 4:50 pm
gtogreen1969 wrote:
There are 2 clubman diagrams in this thread that will help you make a start. viewtopic.php?f=2&t=81633&p=907843
A lot of the mini manuals use diagrams from the UK and they are not exactly the same as our cars.
There is one here for the 1973-1975 Clubman. A little easier to read with pretty colours. http://media.wix.com/ugd/eda60d_cb0d9ce ... dcc35d.pdf
Thanks mate mines a 78 australian made clubman (i think they all were?)
PostPosted: Mon Jul 25, 2016 4:54 pm
but my "cluster" board was the 74 version.... im so confused haha
PostPosted: Wed Jul 27, 2016 5:46 pm
Ok... UPDATE
Got my board on.
And there is still no lights at all.... What the hell? No idea what it could possibly be? No indicator lights at all either...
PostPosted: Wed Jul 27, 2016 6:01 pm
Just in case-
Is your circuit board correct for the instrument pod that you have? 2 pod (no tacho) and 3 pod (with tacho) require different circuit boards.
Eiles
PostPosted: Wed Jul 27, 2016 6:02 pm
When you say no lights. Do you have headlights, Interior light, Parking lights? or is it just the cluster back lights.
If you don't have backlighting inside the cluster it could be the (Panel Light Rheostat). There should be a small black dial attached to the bottom dash rail in front of your right knee. The black knob is marked with a "P". This is the dimmer for the cluster back lights. To test it is the problem you can pull one of the wires off the back and touch it to the other one.
Do the indicator lights work outside the car - is it just the dash indicator lights not working?
PostPosted: Wed Jul 27, 2016 6:17 pm
sounds like you`re computer-savy enough to click onto this mini forum, so my suggestion is to google "asuto electrics" near your suburb & have a mobile auto-sparky pop around to sort it for you
auto electrics are not rocket sience or brain surgery, it`s all pretty straight forward (when you know what you`re doing)
just saounds like you`re spending an awfull amount of time, frustrating yourself no-end instead of just calling a sparky
it doesn`t have to be a mini-savy sparky, just an auto-sparky would do
there`s plenty of help here but seems you`re taking it upon yourself to make decisions spending time & money without diagnising the problem first
diagnosis is the first step,,,
please don`t get me wrong here,,, i help all mini people , all across the world, but you need some structure some diagnosis & some planning before just jumping in ripping stuff out & replacing stuff willy-nilly
keep level headed, stay tuned, stay focuses & get it diagnosed properly first,,, Then fix it from that "correct-Diagnosis"
then you will be able to enjoy driving your trouble free mini :-)
cheers, chin up
it`s work out, it`s just a small silly little issue i`m sure
Matt
PostPosted: Wed Jul 27, 2016 7:14 pm
Hey sorry I have no cluster lights, indicator lights work outside, as do headlights. also the indicator cluster lights dont work also.
PostPosted: Wed Jul 27, 2016 7:15 pm
shnitzee wrote:
Just in case-
Eiles
Hi mate,
no its not the exact one, this is for a 78 mini cluster and mines a 74 mini cluster, same thing but i just had to put the earth wire on thats all
PostPosted: Wed Jul 27, 2016 7:16 pm
I didnt know there was an interior light lol
no horn either
PostPosted: Wed Jul 27, 2016 7:22 pm
The interior light and horn come off the same fuse. These are purple wires. Have you cleaned up the fuse contacts and spade terminals. This is the first and easiest thing to do. Get yourself a multimeter. They start at about $10.
PostPosted: Wed Jul 27, 2016 7:36 pm
No I havent cleaned these up, how do I do that? sorry to be a pain?
Ill grab a multimeter from bunnings on weekend. What are the spade terminals? (Sorry im a very very amateur noob but willing to learn and would love to do as much as i can myself)
I replaced the inline fuse as well behind firewall, do i need to clean these as well?
PostPosted: Wed Jul 27, 2016 7:40 pm
Disconnect the battery first. A spade terminal refers to the shape of the connector at the end of a wire. The fuse box has maybe 10 or 12 wires connected with these push on spade connections. They get dirty and corroded over time.
I use a small wire brush or sand paper to clean the dirty metal contacts. Spray them with some wd40 or similar.
PostPosted: Wed Jul 27, 2016 7:45 pm
Will give that a crack tomorrow thanks. I still am bedazzled as to why there is not even 1 light working....
Could it be that little block ( voltage stabalizer or something?) on the back of the circuit board? That would make sense
PostPosted: Wed Jul 27, 2016 7:46 pm
Do one at a time so you dont mix up the wires. The multimeter can be used to confirm that 12 volts is getting from one side of the fusebox through the fuse and out the otherside into the green and purple wires. You can also check continuity of the fuse with a muiltmeter. Best to leave the multimeter questions for another time.
