It is currently Tue Jul 29, 2025 6:23 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: '66 S horn location
PostPosted: Fri Mar 18, 2016 4:27 pm
Convertible Mini wrote:
The holes for the Horn bracket on Cooper S slammer panel are available at any hardware store on the Sutton stand 1/4 Inch.. No Cooper S tax.
Yes. We all know that will be the final result.
But going straight to the answer misses the pleasure of discussing possibilities and turning over all those scraps of detail buried in our memories.
PostPosted: Fri Mar 18, 2016 5:59 pm
No but there is a GST on the drill bit
PostPosted: Mon Apr 04, 2016 12:58 pm
My June 1967 mk 1 S which definitely has the original slam panel, has the horn mounted on the Lockheed nose bracket mounting bolt, via the 'normal' slam panel bracket, attached to the inner guard. There are no holes for it on the slam panel.
johnl
PostPosted: Mon Apr 04, 2016 2:46 pm
Can you post a photo so I can see how it looks and the amount of clearance it has? I have a few engine bay photos that show horns down in that area but they are not very clear.
PostPosted: Mon Apr 04, 2016 4:07 pm
I'll post a photo in the next couple of days. There is a heap of room down there, no problems with any clearances.
johnl
PostPosted: Tue Apr 05, 2016 9:14 am
As you can see, there is plenty of room under the Lockheed booster. When mounted on the slam panel, the horn is dangerously close to the solenoid.
johnl
PostPosted: Tue Apr 05, 2016 9:15 am
A cooper s slam panel would need to be restamped in a press to add the horn mount holes. My understanding is the body shop tended to stamp large sets of panels and store them in a upstairs storage area of the body shop. So they would stamp up a stock of these at the factory.
Perhaps they ran short of the "special" panels and simply made do using a "normal" panel and relocating the horn? Only problem I could see with this is that they would have to unwrap the wiring harness for the wires to reach to near the booster.
PostPosted: Tue Apr 05, 2016 9:36 am
Fits ok using one bolt hole and mounting the bracket horizontal. The horn may hit the booster if using 2 holes vertically like in bubbaclubys earlier photos.
Users browsing this forum: Majestic-12 [Bot] and 82 guests
