It is currently Wed Jul 30, 2025 8:17 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Feb 23, 2016 4:37 pm
nothing slips past you guys .....
but no verdict?
plate numbers seem to match up
PostPosted: Tue Feb 23, 2016 5:43 pm
Impossible to give a verdict if it is a genuine car from the photos. It has what looks to be a genuine ID plate but that could have been attached to a deluxe body shell 20 years ago. If it is a genuine car it has had a lot of parts swapped out and would need a bit of time and money if you wanted to put it back to original. Seats, heater, carbies, brake servo, speedo, master cylinders, alternator, cylinder head, steering column shroud and indicator stalk.
PostPosted: Tue Feb 23, 2016 6:01 pm
I can't see anything in the photos that makes me think it is a Cooper S but I can see a couple of things that make me think it might not be one.
PostPosted: Tue Feb 23, 2016 6:08 pm
Hmmm looks like a bitsa to me :?
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Tue Feb 23, 2016 6:28 pm
So here's where I'm at, at the moment.
I'm thinking, trying to find a legit car, fully restored with provenance is going to cost me $40k (more than my budget).
Car 2718 looks neat, has been resprayed and has a lot of money spent on it. For $18K I think its a fair price (he has sent me photos of receipts totalling $15K)
The car is currently at a Mechanic pending a "pre-purchase inspection" .. Murray's Motors QLD.
I have contact QLD mini club and they MAY be able to find someone to authenticate the vehicle.
For $18K I'm happy to blast around in it for a while and maybe sell it for a small loss later on. In the meantime I can learn more about them and wait for a very special one to come up.
Am I being "Mini Delirious" ?
Also, how can I do PPSR (Revs) check on it as it doesn't have a VIN plate?
PostPosted: Tue Feb 23, 2016 7:11 pm
It is registered with chassis 2718 so try using that. I Haven't done a revs check before to check for encumbrances -I just use the online rego checks to check chassis and engine numbers.
https://www.service.transport.qld.gov.a ... ndowId=a8a
PostPosted: Tue Feb 23, 2016 7:37 pm
If you need someone to check it out I'm in Brisbane qld and have some contacts that know quite a bit about cooper s's. Murrays motors is only 20 minutes from my place.
Regards
Rod
PostPosted: Thu Feb 25, 2016 4:23 pm
I thought I'd provide an update on those interested....
I had the car inspected at Murrays Motors a "Mini, Leyland, Austin specialist" and subsequently spoke to the mechanic, Murray.
He assured me it was a "good one" and gave a very good character reference for the seller, whom had known for many years.
For better or worse, the engine has been swapped out, it is currently powered by a 1100s motor (12DTAH8795) the suspension has been changed to Hydro (I don't know what that means).
It runs well and is free from rust.
I'm now a very excited Mini Owner (albeit a Bitsa). Maybe one day The Finance Dept may allow me to collect a "100percenta"
PostPosted: Thu Feb 25, 2016 4:34 pm
If it is a genuine Cooper S it should have Hydrolastic from the factory. Instead of coil springs like a normal car it has fluid filled rubber bags that act as springs and shocks.
http://www.elevenhundred.com/hydro.php
https://en.wikipedia.org/wiki/Hydrolastic
Older (and newer) minis have "dry" suspension which is solid rubber springs
PostPosted: Thu Feb 25, 2016 5:06 pm
I have the phone number of the owner from 2 years ago in Sydney. Pm if you want it.
PostPosted: Thu Feb 25, 2016 8:07 pm
Online
At the end of the day are you happy with the car and what you gave for it ? , either way you will have the same amount of fun whether it is a genuine S or someones version of an S depending on what they told you it was if it performs as one .
PostPosted: Fri Feb 26, 2016 6:46 am
Welcome to the world of minis, now to get your hands dirty !!
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Fri Feb 26, 2016 6:01 pm
Well as long as you are happy with it that's all that matters really :D
1965 Morris 850
1977 Leyland LS
PostPosted: Sat Feb 27, 2016 7:00 am
Right on :!: :D
Users browsing this forum: goodie and 110 guests
