It is currently Mon Jul 28, 2025 1:04 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Aug 22, 2016 8:52 pm
I had one of those Green bearings, is now sold. Pretty sure they are NLA now, as are the Timken and SKF flat ones.
PostPosted: Mon Aug 22, 2016 9:28 pm
another pretty obvious alternative is to source a similar flat faced thrust bearing and either sleeve the thrust carrier bigger or machine it down to suit
or modify the wok and make one of these work http://www.eeuroparts.com/Parts/84495/S ... r-4926028/
PostPosted: Mon Aug 22, 2016 9:48 pm
I have bored out a hard diaphragm thrust plate to clear a 5203 double row bearing's side seal. It is 17mm ID, so will need a bush made to fit the 5/8 shaft. It will go in my car at Xmas when I swap gearboxes.
Having said this, I put an orange dot clutch in my car 10 years ago with an RHP brand 7W5-8 current style bearing.
It is still fine, mind you I don't sit at the lights with the clutch in. :lol:
