I think that maybe all the talk of engine work may make people think that Minis aren't reliable. Like Wombat's other thread about rebuilding an engine (where everyone's telling him to keep a 998 block out the back as a spare). But I'd reckon that a fair amount of the engine work that gets talked about on here isn't necessitated by problems, it's created by that urge that Sports850's talking about.
You can get a bit on a Mini with "bolt on" mods - exhaust and carbies - but you'll get much more if you play with the head, cam (which is an engine out job on a 1275, but not a small bore - one advantage of a small bore), etc. And when you're improving things at the top end, you want to make sure the bottom end's strong enough to handle it. Rob's (CPOCSM) 280,000km factory engine isn't too shabby by modern standards, even better when you consider it's run all that time in its gearbox oil!
For my point of view on this one, a 1275 will give you the highest ultimate power output - dollar for dollar, all things being equal. But there's nothing wrong with the old small bore. Not everyone can afford a big bore. And plainly some don't want a big bore. For mine, as long as it will keep your Mini going, it's worth something!
But obviously everyone has a different dollar figure - from zero to much more than that.
