It is currently Sat Jun 21, 2025 2:20 am
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Lucas 29d springs
PostPosted: Mon Oct 21, 2024 12:37 pm
cooperess wrote:
Please forgive my ignorance but don't you need 2 springs and don't they both need to be different.
Usually they are two very different springs but not always.
For example, there's a mini spec 43d which appears to have two identical springs. I pulled two apart and they both looked to have two springs the same.
The heavy spring isn't constantly under tension so doesn't need to be replaced as often unless the curve is to be changed.
Because most of my engines are 998s, I'll probably keep needing the same spec springs. Buying a set of five doesn't make sense.
Too many minis
