It is currently Sat Aug 23, 2025 5:09 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23 ... 568  Next
PostPosted: Sat May 09, 2009 12:34 am
finnally finnished working on the mini :P ( took a lot longer then i thought but i got there), c.v. and wheel cylindars... went for a spin and so far so good.
PostPosted: Sat May 09, 2009 7:11 am
more blining of the Gr Manifold. Another 3 hours and it should be finished :lol:
PostPosted: Sat May 09, 2009 8:07 am
Banged my flywheel cover :lol:
PostPosted: Sat May 09, 2009 9:06 am
Tomboss Breweros
Put Ultra blue globes in the headlights. 8)
Made the park lights in the headlights work 8)
Looked upon it and said "It is good" 8)
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat May 09, 2009 3:13 pm
Assembled the starter motor after the paint had dried
Stripped the bright green paint off the hinge the Doc sent me and cleaned up my good one and gave both a coat of etch primer.
Made up some zinc electroplating solution but the things I want to plate are showing signs of being greasy so I'll have to soak overnight in some degreaser and try tomorrow.
Had the local brake place put a bubble flare on each end of a short piece of brake pipe to go between the T piece on the firewall and the brake switch connection on the sub frame - was just about to bend it to shape and realised the sub frame is still in the lowered postion as I haven't put the steering rack back :roll:
PostPosted: Sat May 09, 2009 4:54 pm
Stripped my Engine Bay (components) so I can strip my Engine Bay (paint).
Dicko
PostPosted: Sat May 09, 2009 5:05 pm
The TIG
I picked up my rebuilt generator from the shop and I bolted it back in the car. Did not have much time to work on the car today.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Sat May 09, 2009 5:10 pm
Finshed Bling the Manifold 8) went to take a Pic for you all but every battery is dead :twisted:
PostPosted: Sat May 09, 2009 5:12 pm
:twisted:
Dicko
PostPosted: Sat May 09, 2009 5:39 pm
I went to take some pics too, and the lithium ion battery went dead. Not to worry, I carry 2 x AA lithiums just in case!! :P
PostPosted: Sat May 09, 2009 6:08 pm
Finished 3/4 of the internal boot hinges. Hopefully have it fully finished tommorow and I'll put up some pics.
PostPosted: Sat May 09, 2009 10:54 pm
FINALLY got BC back on the road!!!
Changed the points, condensor and coil and all good. Just some tweaking needed as it's missing at around 4k. Something about that number and misses!
:D
PostPosted: Sun May 10, 2009 9:30 am
still havn`t done anything to it :-)
PostPosted: Sun May 10, 2009 10:01 am
maybe not just today, but in the last few weeks I have deseamed the passangers rear quarter, bought new apron, fitted front stepped drums, and possibly sourced out a stroked 998. May deseam drivers rear quarter today. Deseaming is such a long slow process!
mooo, I'm a pig!
PostPosted: Sun May 10, 2009 10:55 am
This space for rent
It is if you do it properly ;) :)
Users browsing this forum: No registered users and 238 guests
