It is currently Fri Aug 22, 2025 10:12 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 568  Next
PostPosted: Wed May 06, 2009 3:28 pm
Well! I went out and installed another electronic ignition module in my car, and it worked! :D Details in another thread. No pictures, willy.
Now wondering about the smoke coming from underneath the extractor on Cylinder 4... :? It starts as the manifold heats up, so I'm thinking it may be a little spilled oil from the oil change I did at the same time as the electronic module, believeable because, given my dramas with the electronic ignition module (again, see other thread. And previous post in this one), the engine wasn't been fired after the oil change until today. Might buy some degreaser... Hope it's not anything more serious that spilled oil. :roll:
Also found that the oil leak (doesn't every Mini have a small oil leak?) is on the driver's side (which I already knew), and it's landing between the sump and subframe, and between the sump plug and the driveshaft. Not a big leak, just leaves a small (maybe 9"sq - 3"x3") patch, marking its territory. Any tips on what the oil might be dripping down there from..? :?
PostPosted: Wed May 06, 2009 3:43 pm
Fixed an oil leak on Bez's newly rebuilt 1293A+ motor.
It was slowly dripping from below the diff.
Problem- somebody before me bent the ear on the diff side cover so it didn't seal the detent O-ring.
Easy fixed- grabbed another cover. :lol:
PostPosted: Wed May 06, 2009 4:39 pm
Olayed with the wireing for the van and think I have nutted it :wink: just got to send a PM :lol:
Doc also cam over to take valve's out of my 940 head. A little work and shes a good one 8)
PostPosted: Wed May 06, 2009 5:00 pm
Changed out temperature sender with another I have....it started to show 1/4 warm when the block temperature was only 15 degrees :shock:
I know they're prone to overheating the old minis, but that was ridiculous....
PostPosted: Wed May 06, 2009 5:41 pm
disconnected everything in my toy so i can pull the engine out tommorrow,for cleaning and painting & fitting bling must be ready for july
PostPosted: Wed May 06, 2009 7:07 pm
I fitted all the tail lights, put in all the interior trim and put the bumpers back on my matic.. also hopefully to be ready for july :D
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Wed May 06, 2009 7:15 pm
tried to change the speedo cable in mine over but found out that you have to take the engine out to get to it easily so will do it later, just have to guess my speed :)
I'm grew up on the street, not the hood, the sesame st
PostPosted: Wed May 06, 2009 7:19 pm
You don't need to take the engine out. It is tough but you can do it.
PostPosted: Wed May 06, 2009 7:22 pm
yer we could get to it, but gave up and will do it when we do the clutch plate and gear seal so we get a bit of wiggle room, thanks though
PostPosted: Wed May 06, 2009 7:30 pm
why is it on that side? mines near the timing chain
Potato
PostPosted: Wed May 06, 2009 7:36 pm
sorry that made sense with all the stuff i had thought about, forgot you hadnt thought about it :P ,
Well we have to unbolt the engine to do the clutch plate and gear seal. So when its kind of off out we might get a better angle to get at it.
PostPosted: Wed May 06, 2009 10:44 pm
today i put3/4" rear wheel cylinders in the delux, and got some new formula R s put on rims and did some handraking tests :D success!
nearly ready for hay hay
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed May 06, 2009 11:23 pm
Come on guys, its not too hard to get pics uploaded :!:
Everyone likes to look at pictures...
PostPosted: Thu May 07, 2009 12:18 am
Ok only because you asked nicely :)
Getting the LS ready for Around the Houses Event.
Ohhh-Hope that's not too many pics :lol:
PostPosted: Thu May 07, 2009 1:03 am
http://www.googajoob.com/v3/index.php?module=article&node=search&page=display&articleid=23
Some troublesome clutch pics :)
And thats a nice looking LS you have there. :o
Users browsing this forum: Sahig131 and 204 guests
