It is currently Fri Jul 11, 2025 12:17 am
 Post subject: Re: Master cylinders
PostPosted: Mon Apr 29, 2019 5:02 pm
Clive, Many thanks . I have 5 of these spacers in my spares bin and had no idea until now I know what they were for
Mk1 Cooper S
Mini K Rally car
PostPosted: Wed May 08, 2019 7:00 pm
Just to add to this thread - These are the change over points for a few other minis and mokes.
PostPosted: Thu May 09, 2019 10:43 am
gtogreen1969 wrote:
glenndunn wrote:
Mine is 3688 I have never seen the plastic extensions befiore, never seen them is any of the mini sellers catalogues.
Where would I be able to get them
Here is one example https://minikingdomonline.com.au/produc ... with-seal/
Just be careful when you screw the extensions onto the tin tanks. Too much force may break off the threaded section which is only soldered on.
Which is what I did (ham fisted). So next time I used a smear of RTV on the rubber seal to prevent any brake fluid leakage. As you know, conventional brake fluid will leak out anywhere it can find a spot, then destroy everything in it's path :evil:
