It is currently Fri Jul 18, 2025 8:16 am
PostPosted: Tue Jan 08, 2019 4:21 pm
gtogreen1969 wrote:
winabbey wrote:
That new 4ST introduced at 3966 sill had the "manual-operating control" button. So at some point after that it was replaced again by a 4ST without the button (i.e. part 62933009). ;)
Yep - I haven't worked out when the 4ST lost its push button. We would probably need to look at the one owner cars.
Looking at photos won't help that much as they kept the little cap on the non push button type.
I have 2 of the square 4ST with the usable push button and they both have red buttons. Most people don’t believe me that square type originally had a push button until I demonstrate it.
PostPosted: Tue Jan 08, 2019 4:25 pm
Are they dated or do you know what cars they came off?
PostPosted: Tue Jan 08, 2019 7:32 pm
I'm also interested to know if they are Lucas Australia with a date stamp and part number Phillb.
There's got to be a few around for sure.
PostPosted: Wed Jan 09, 2019 10:03 am
Don’t know what off. They should be dated. I’ll check tonite if I remember.
PostPosted: Wed Jan 09, 2019 10:57 am
Here is the Lucas Australia solenoid I have. It is not push button and don't know if it came with my car when new.
PostPosted: Wed Jan 09, 2019 10:59 am
Is it the push button start type and do you know if its original to your car?
PostPosted: Sat Jan 12, 2019 11:50 am
I have 2 of the square type that has the small red push button between the terminals.
The date is in the black plastic part though.
Edit: on the metal part they both say Lucas England 4ST
One is 76766E 4969 (week49?)
Other is 76766F 0269 (week2?)
PostPosted: Sat Jan 12, 2019 1:00 pm
Thanks for posting those Phill.
The Lucas Australia parts book lists the UK made 76766 solenoid as being for the AH Sprite, MG Midget and MGB, so CKD vehicles that were assembled here. These vehicles had very few local parts according to the parts books.
I haven't seen any documentation to support the 76766 solenoid being used on the Australian Mini range.
PostPosted: Sat Jan 12, 2019 1:13 pm
So was there an Aust version of the same type with a the push button??
PostPosted: Sat Jan 12, 2019 1:36 pm
I don't know but I assume not until an actual example with Lucas Australia branding and date appears. Going by the narrative in the SLS gtogreen1969 posted earlier there was a solenoid with push button for a period but perhaps this was UK sourced, maybe BMK1727 as per the parts book I posted previously.
PostPosted: Sat Jan 12, 2019 5:57 pm
I've found two Australian Lucas solenoids this week which have the black top button.
One is dated 10/72 and the other is dated 1/76.
Lucas Australia - the part number and 12v + date all appear on the bracket.
PostPosted: Sat Jan 12, 2019 6:09 pm
Are you talking about a button that operates? The 62933009 solenoid has a black knob but it's part of the solid plastic enclosure and isn't a button.
What is the part number on those?
PostPosted: Mon Jan 14, 2019 6:45 pm
On the 72 solenoid it reads 6/72 not 10/72 sorry.
The part number is the same but reads 629330090 so a extra 0
Yes the black knob is part of the solenoid.
PostPosted: Mon Jan 14, 2019 7:57 pm
That 0 suffix may be a D. Lucas routinely used an alpha suffix to show a running change to a part.
PostPosted: Mon Jan 14, 2019 8:55 pm
I had a bit of a google and it looks like the BMK1727 is sold as a 2ST and 4ST. There are too many cross references for it. A 1960s catalogue with pics would help if we could find one.
Whichever one (either BMK1727 or 76766) was first used it wasn't long before the non push button 62933009 Aust version started in 1968.
