It is currently Sun Jul 13, 2025 1:46 pm
 Post subject: Re: Engine paint detail
PostPosted: Tue Oct 02, 2018 4:04 pm
Here is the better quality scan for you. The lack of washer bottle is a little puzzling!
PostPosted: Tue Oct 02, 2018 4:43 pm
Bill B wrote:
The bar is natural, zinc plated; the brackets (obscured by the heater tap) are satin black but the 2 bolts and spacer washer on engine end (just visible) are also zinc.
Thanks Bill,
That's what I was thinking. I did the Steady bar with a zinc coat.
Cheers, Alan.
PostPosted: Tue Oct 02, 2018 6:39 pm
Who knows what they did with the washer bottle. Maybe they took it off to top up the water and lost it.
The scans are much appreciated. Now to find a colour pic.
PostPosted: Tue Oct 02, 2018 7:11 pm
Bill B wrote:
I have just had a small tin of metallic green mixed at a local Motospray outlet. They included the formula, which is in their Auto Enamel line.
I don't know if NZ has Motospray brand - it was owned by Hi-Chem and now by Rustoleum, which is in NZ.
But the formula for this colour can't be used with a different brand.
The engine green metallic is very, very, very similar to an old 1970s Chrysler/Mitsubishi(Aust) colour called Sherwood Green (Met.) which might be easier to track down.
It looks like this.
Hi Bill B
Thanks for your info and I will look into Rustoleum.
I have looked at an Australian BMC Paint colour chart in the last few day's and found Metallic green Metallic in the trim colours.
1967 show's this colour under Duco with a code of 10489.
The next time Metallic Green appear's is 1971-72 under trim colour and is also Duco with code 13357.
The trim colour chart also show's Silver Birch and Silver Ash which I understand is the wheel rim colour's.
Working on these codes to see what might turn out for a colour match.
Interesting project :lol:
PostPosted: Wed Oct 03, 2018 10:05 am
Firefirey wrote:
Hi Bill B
The 2 different Duco paint codes for Metallic Green might be due to Dulux: I think the first 2 numbers in their paint codes referred to the line or system of the paint material. If so, then the actual colour could be the same but in 2 paint systems, with "13" replacing the "10" system.
With the wheel colour - I know the Cooper S wheels were a darker grey than the wheels made in Aust for Deluxe and K models.
