It is currently Sun Jul 13, 2025 6:25 pm
PostPosted: Tue Jul 17, 2018 8:10 pm
... or sit in the car and get someone else to do it, ensuring they are young enough to not have a heart pacemaker fitted. :shock:
PostPosted: Wed Jul 18, 2018 9:24 pm
Unfortunately I learnt the hard way how to check the trembler coils on a running Model T. My Dad and his mate thought it would be hilarious to show me how to check the points and drop a cylinder out, but failed to tell me not to touch the top and bottom bridge of points at the same time. Needless to say I’m VERY careful when I do it now. It’s only 6v, but st 1.5A it packs a pretty good punch.
PostPosted: Wed Jul 25, 2018 8:41 am
simon k wrote:
JEA wrote:
you could hear and feel it back firing through the RH carby.
I reckon there's a bit of a clue in this - while it's running, take the spark plug lead off each cylinder in turn, starting with #1 - I don't think there will be any difference when you take #1 and #2 off, but it'll conk out when you take off #3 or #4
you might get a shock or two, you'll get over it, just be brave when you grab the lead, you're more likely to get a shock if you're hesitant
Or you could use a set of these , old school eh :!: :P
PostPosted: Mon Sep 17, 2018 6:05 pm
I’m having similar issue as you? Did you have any joy sorting this out??
PostPosted: Tue Sep 18, 2018 8:15 am
Check the coil is not wired backwards. Will still work but with reduced output voltage. Can give funny results.
