It is currently Mon Jul 14, 2025 12:49 pm
 Post subject: Re: Diff Cage AYG3037
PostPosted: Sat Jun 02, 2018 5:37 pm
winabbey wrote:
cooperess wrote:
Googling BTA142 and AYG3037 has come up with zero responses.
BTA142 appears in the Morris 1100 parts book, and seems to be very similar to BTA145. No idea what the difference is.
You can't find AYG3037 because BMC used the UK part number BTA145 in parts books and other external references. See the drawing below.
Doug, Do you have any insight to the history of the BTA series of Part Numbers? They pop up all over the place. Thanks.
PostPosted: Mon Jun 04, 2018 12:45 pm
I've done a bit of searching and can't find much about the origin or meaning of the BTA prefix, except that it is mainly used on suspension and steering parts.
PostPosted: Wed Jun 13, 2018 1:07 pm
I have just purchased a NOS BTA145 and it is packaged in a box marked BTA145 but embossed BTA142. What the!!
PostPosted: Wed Jun 13, 2018 2:37 pm
Part numbers are often different to casting numbers. One casting can be machined or even used as is for different applications and therefore have different part numbers.
I'll do some searching to see if this is the case here.
