It is currently Wed Jul 16, 2025 7:15 am
PostPosted: Fri Feb 02, 2018 12:42 pm
Hobson wrote:
Maybe they need a universal rename to ShortShifts
Some are named correctly. https://www.minimania.com/part/C-22A175 ... Rod-Change
PostPosted: Fri Feb 02, 2018 7:19 pm
$300?! That's absurd. I'm with Doc on this. Get the hacksaw out...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Fri Feb 02, 2018 7:34 pm
Cutting the lever short doesn't make it a short shifter...
You need to lengthen the shifter under the pivoting cup, raise the pivot point and then you have a short shifter.
http://www.build-threads.com/project-51 ... -shifting/
PostPosted: Fri Feb 02, 2018 8:03 pm
Sure it does, theory of levers. Cut in half it has 1/2 the travel...
And twice as hard to push too.
