It is currently Thu Jul 17, 2025 3:49 pm
PostPosted: Mon Dec 18, 2017 5:16 pm
I'll be fitting an isolator switch to mine and definitely a cover after reading this.
Having it hidden inside the car is a good idea too. Bonus security.
PostPosted: Mon Dec 18, 2017 7:43 pm
I changed a wheel and just threw my jack into the boot, down the bump driveway and the jack shorted between the +'ve terminal and the metal fuel line to the RH tank - interior full of smoke, jumped out, opened the boot, flames jumping out at me, back in, grab the extinguisher and put it out....
everyone needs proper battery terminal covers AND a fire extinguisher in an accessible place
PostPosted: Mon Dec 18, 2017 8:31 pm
Battery cover and don't have stuff floating around the boot..
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sun Dec 31, 2017 6:58 pm
When holding a Drone to connect a Lipo battery and it goes up you throw the drone away without considering how much damage to the drone you gave to fix
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
PostPosted: Tue Jan 02, 2018 10:32 pm
The cover doesn't need to be too fancy. A rubber matt over the whole floor of the boot will do.
The isolators with the round knob on them do the trick in the boot and aren't expensive. Isolate in a jiffy.
Alec
PostPosted: Wed Jan 03, 2018 6:05 am
I have a boot board sitting on the Contessa spare wheel and all my junk, jack etc in a plastic bin.
