It is currently Sun Jul 06, 2025 10:37 am
 Post subject: Re: Radiator Choice
PostPosted: Mon Jul 20, 2020 10:29 am
FNQ wrote:
I purchased multiple alloy 50 mm ebay items ( sorry local suppliers/ welders , i just couldn't justify 4 or 5 times the price) approx $90.
you need to measure your widths, as the cheap ones vary from about 51mm to 58mm. ( also check visually on the fall of the height from top rear to front as i have heard some rub the underbonnet.)
I run one in a race engine overbore but shortstroked ( 73.5x 76) , as doc mentioned, run a auxillary tank. ( i use the good old moke ones and as advised by a clever mini engine builder/racer, use it as a proper header tank not just an expansion tank) Others are in service in other race engines, so cooling power is excellent. Cheers Darryl
74 degree thermostat, Speedflow 6AN 3/8" Pushlock Aluminum Weld On Barb Alloy Fitting 989-406 ( good ally thickness for welding onto radiator neck in my instance)
these are the ones i used and am happy with for fit and purpose but probably lots and lots of similar....( welding of rad is actually very good as commented by the welder who welded on the barb fitting)
AUSTIN ROVER MINI 1275 GT 1959-1997 50mm ALUMINUM RADIATOR from worley parts on ebay
Is that one of these? https://www.ebay.com.au/itm/121106088737
Any shroud/guard cutting required?
PostPosted: Mon Jul 20, 2020 3:02 pm
I've got this one - no cutting, etc needed. Works a treat keeping my 1275 cool.
https://www.ebay.com.au/itm/52mm-alloy- ... 2749.l2649
67 Van, 1275cc
PostPosted: Mon Jul 20, 2020 4:21 pm
Hi John Deere
I don't know if it was that seller exactly ( sorry my ebay history doesn't go back far enough) but it was a worley and At 52mm overall width it fitted without any shroud cutting. ( the one you pointed to has the 50mm core which is ideal ,,, others have 40mm core. The only thing to add was the radiator comes with a front bottom plug ( good thing if you can get your spanner on it, but look closely at the rubber o ring supplied as some are pretty average
PostPosted: Mon Jul 20, 2020 10:42 pm
Thanks guys.
