It is currently Fri Jul 18, 2025 6:09 am
 Post subject: Re: first motion shaft S
PostPosted: Fri Jun 30, 2017 7:02 pm
well got the bearing issue sorted
and the new baulk ring arrived today and it bottoms out the gear and it has a sloppy fit
should i turn 10 thou off the baulk ring.
this one is fighting me to the end
PostPosted: Fri Jun 30, 2017 9:31 pm
I and others take .020" off the old baulk rings for more life.
Not had a problem.
PostPosted: Sat Jul 01, 2017 7:51 pm
Not had a problem.
After reading previous posts re which baulk ring to use i have turned the best old style baulk ring down 2o thou and now have clearance. Thanks for the posts.
Sent from my GT-I9505 using Tapatalk
PostPosted: Sat Dec 09, 2017 11:50 am
Has anyone tried this option to upgrade their gearbox to Cooper S status?
http://www.minispares.com/product/class ... 4032A.aspx
PostPosted: Sat Dec 09, 2017 1:11 pm
Yes I have done about 4 over the years. However last time we fitted a 3.1 diff instead. This gives you the same 1-2-3 ratios as a MK 2 S but a taller 4th. Better for cruising.
And it's about 1/2 the price now.
PostPosted: Mon Dec 11, 2017 4:42 pm
At great expense I had my Mini K gearbox rebuilt with close ratios. First time around synchro didn't work 2nd and 3rd gear. Had to pull the engine and get it redone. Excuses I didn't understand. Was a complete PITA. Having said that, all is good now and the gbox works really well with the engine. Can do close to 100 km/h in 2nd but I don't do that anymore, I was "testing" :-)
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
