It is currently Wed Jul 23, 2025 12:41 am
PostPosted: Wed Feb 22, 2017 5:29 pm
I would be inclined to clean it up ,pull it apart and inspect the bore as previously said , they are not hard to rebuild , it may only require a hone and a new kit .
PostPosted: Thu Feb 23, 2017 6:53 am
Brake Smart in Fairy Meadow are quite helpful if you decide to get it honed or sleeved.
55 MONTAGUE STREET, Fairy Meadow, NSW, 2519
PostPosted: Sat Feb 25, 2017 8:04 am
gtogreen1969 wrote:
peterb wrote:
Disc and drum ones are usually different. One has a line pressure valve.
Isn't that the brake and clutch difference?
I agree with peterb. drum brake M/C had a valve to hold pressure against the wheel cylinder cups, for better application. Disc brake M/C didn't have the valve because they didn't have return springs like drums and had to self release.
Dalmeny
PostPosted: Sat Feb 25, 2017 10:41 am
I thought all brake master cylinders had a non return valve.
At least all my cars do and the rubber kits always include the valve
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Feb 25, 2017 3:14 pm
It is not a non return valve, it is a return flow restrictor. Disc brakes will work with or without it.
PostPosted: Sat Feb 25, 2017 3:42 pm
Thanks all for the help. I've ordered a "drum" tin type GMC171 complete replacement unit. I'll probably keep the old one as a spare if it can be rebuilt.
