It is currently Sat Jul 19, 2025 1:14 am
PostPosted: Tue Jan 24, 2017 10:39 am
Thanks for all your input. I will get back to you with some more info on the car
PostPosted: Tue Jan 24, 2017 10:43 am
Floor starter hole?
PostPosted: Tue Jan 24, 2017 2:46 pm
Bubbacluby wrote:
It has heater hooks.
850s and deluxes didn't have heaters.
Could be a Cooper of some sort
Some English 850's did
Sent from my SM-G935F using Tapatalk
PostPosted: Tue Jan 24, 2017 3:11 pm
Could be a Cooper of some sort.
not true my 850 has "heater hooks", no heater but the hardware was there.
starter hole and "hacked" remote hole all point to it being an 850
PostPosted: Tue Jan 24, 2017 3:28 pm
Oh ok.
Always thought it was only Cooper and S's had heaters.
PostPosted: Tue Jan 24, 2017 3:58 pm
my car never came with a heater, and had the blanking plate over the holes where the hoses went, so most likely never had a heater until I put it in there.
I should point out that my car is a mid '63 car.
PostPosted: Sun Feb 05, 2017 4:42 pm
I have some more photos of the drain holes in the roof channels and some other photos
PostPosted: Sun Feb 05, 2017 4:45 pm
Just some more photos
PostPosted: Sun Feb 05, 2017 5:06 pm
Is an aussie shell
PostPosted: Mon Feb 06, 2017 7:44 am
If its a Aussie shell what kind of shell is it??
PostPosted: Mon Feb 06, 2017 8:47 am
Does the boot have holes for boot board brackets
PostPosted: Mon Feb 06, 2017 1:56 pm
with a number in the 39,000's, no cutout for an 850 gearstick and no hydro channels I'd guess it was a '66 Deluxe. Take some paint off the radiator shroud and you might find an M2/xx number
doesn't matter what it is, you know what it isn't - it isn't a Cooper, it isn't a Cooper S and it isn't an English body
looks like a great starting point for whatever you plan to do with it
PostPosted: Mon Feb 06, 2017 2:53 pm
On the main body can you put up a pic where the door latches go
PostPosted: Mon Feb 06, 2017 7:40 pm
the door pictured above is a windup...
PostPosted: Tue Feb 07, 2017 4:51 am
I wanted to see on the body if it has the early striker latches and someone's put wind up doors
