It is currently Wed Jul 23, 2025 8:49 pm
 Post subject: Re: Mini k speedometer
PostPosted: Fri Oct 07, 2016 8:27 pm
gtogreen1969 wrote:
You would need a one owner Mini K to confirm the kph speedo.
I am sure hundreds were changed over the years for those that can't workout the conversions in the head.
I bought an XA Falcon 351 in 1973. It had a mph speedo.
I didn't do any conversion for kph, but I did get places a lot quicker 8)
PostPosted: Sat Oct 08, 2016 8:00 am
I've had a 69, 70 and 71 Mini K (should never have sold them of course!) and am pretty sure they all had km/h speedo's, definitely the 70 K one as it's now in my Deluxe. (The 71 car had those horrible flip up door handles)
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Oct 08, 2016 8:13 am
gtogreen1969 wrote:
Maybe early clubman poverty pack and mokes.
Mine is in miles
Sent from my SM-G900I using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
PostPosted: Sat Oct 08, 2016 10:35 am
My 1970 Matic (same body) was 90MPH. Ditto a '69 Matic I had.
If metric, someone has changed it, IMO. Even early Cubbies were MPH.
Btw yes I was here then, driving Minis and Fiats. :)
PostPosted: Sat Oct 08, 2016 11:32 am
Our 1969 K has a MPH speedo, but then as it is a very early one it would be expected. I have seen a lot with the sticker MPH/KPH overlays on them. The odo is still in miles of course.
As there was no requirement for the speedo face to be in KPH before 1 July 1988 manufacturers could have gradually changed over at their leisure. In fact, prior to this date, there was no requirement to actually have a speedo.
Don't listen to what I am saying... just understand what I mean.
PostPosted: Sat Oct 08, 2016 1:26 pm
Our 1970 Mini K is in MPH, we have had it from new, I think it is 4th month 1970 build.
PostPosted: Sat Oct 08, 2016 2:05 pm
The Mini K production period was March 1969 to June 1971 so I doubt any vehicles were fitted with a metric faced speedometer from the factory. Certainly the BMC Australia engineering drawing for the K speedo (part AYA9165) shows mph only.
PostPosted: Sat Oct 08, 2016 7:27 pm
9YaTaH wrote:
NOT850 wrote:
If you're interested I can put a picture up of it. The face is in good shape just the rubber type gasket behind the glass has perished.
Please do...the "made in Australia" part has got my interest :D
Local manufacture don't seem to have been proved so far...the engineering drawing is too low rez to see if there are any clues to local suppliers etc
Smiths Industries in Sydney may have got some work silk screening Km/Hr dials for pommie speedos but I don't recall them making the instruments themselves...
PostPosted: Sat Oct 08, 2016 8:08 pm
I understood the MK 2 S speedo was local. It had Australian R&D clues 'lets make this puppy cheaper'. Coloured plastic sheet for its lamp bezels??
PostPosted: Sun Oct 09, 2016 8:04 am
That's really odd because I have a km/h one and it was taken from a 70K I wrecked....
The numbers are:
SN 4421/116 SA with "860" under the 1/10's scale.
67 Deluxe
Dry suspension
PostPosted: Sun Oct 09, 2016 9:15 am
That could also be pommie cost cutting I suppose...keep searching that (vast) memory bank Doc :D
PostPosted: Sun Oct 09, 2016 9:16 am
The numbers are:
Sounds like a Moke one.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Sun Oct 09, 2016 10:31 am
Did you click on the image? It opens in another window and is clear to read (for me anyway). :)
I don't know if it was made locally, just that it has an Australian part number which is usually a good clue.
PostPosted: Sun Oct 09, 2016 5:03 pm
Thanks...Yep, Smiths proprietary item with a BMC number allocated (which is common thing to do)...
PostPosted: Wed Oct 12, 2016 12:25 pm
Just an afterthought re my km/h speedo (regardless of it's origin!) that may be of use to some of you.
At the top of the dial is an unused green light. I had an idea. What I did was to wire it up to my electric fuel pump so I know when my secret cut off switch is on. i.e no light, pump isolated, green light on, pump on, ready to roll! I have a few times driven off only to splutter a few hundred metres down the road. Quick check, no green light, idiot! Hope this is of help...
Michael
67 Deluxe
Dry suspension
Users browsing this forum: BBY755, Bing [Bot] and 106 guests
