LittleHoju wrote:
The 998 MiniMatics are slugs. They should have put the 1098 in it.
I had another Matic with a 1275 auto put in it, that was better. But still nothing like a manual.
Bit of a thread revive.
I assume this was a Morris 1300 auto engine and box?
In the past month looking for matics nearly all of them have had some sort of gearbox issue, or come with a spare engine that did have gearbox issues.
This seems to be put down to the sharing of oil between the engine and the gearbox.
I'm wondering if the morris setup is the same and suffers the same issues?
If not, seems like putting one of those in a matic solves the sluggishness and longevity issues.
not sure how often they come up though...
A friend of mine owned it, he took the motor and gearbox from a Morris 1100S (1275) automatic and dropped it into the Matic.
Gearbox is the same as a 998 Matic.
The gearing was pretty low for a 1275 with the Mini's 10" wheels, so he put 12" wheels and high profile tyres on the front.
I sold the car to a friend on here, he fitted twin HS2 carbs and it went fairly well. He then resprayed it in white 2 pack and sold it. To another ausmini member.
Yes it shares the oil same as a manual does, that's why they MUST have frequent oil changes. Facing material from the auto's clutch plates gets into the oil as they wear.
