It is currently Sun Jul 27, 2025 11:50 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Aug 09, 2016 10:19 pm
MinisPlus
http://www.minisplus.com.au/old-shop/pr ... e-deadener
These are Australian made, not imported, have the flap and if needed the hole for the fresh air heater can be easily cut in them.
How can it be rusty when it's covered in so much oil?
PostPosted: Wed Aug 10, 2016 5:46 am
gtogreen1969 wrote:
What is the difference between the two?
The Wiper Motor is in a different position from what i can see
1970 MK2 Cooper S
PostPosted: Wed Aug 10, 2016 6:00 am
Also the question was
Where can i buy this type of matting so i can shape my own
1970 MK2 Cooper S
PostPosted: Thu Aug 11, 2016 5:51 am
So no one knows where to buy this material
1970 MK2 Cooper S
PostPosted: Thu Aug 11, 2016 8:46 am
Sorry mate, don't know where to buy a blank sheet of material.
PostPosted: Thu Aug 11, 2016 9:52 am
The Mini King
GundyGuy wrote:
Got the bulkhead felt from MKOL and it doesn't suit a MK2 Cooper S
Its made to fit a MK1
So does anyone know where i can buy some similar material so i can cut my own to suit my car
GundyGuy,
I am sorry you are unhappy with your purchase, I am happy to refund you, just let me know
and I Will post you a prepaid envelope and you can send it back, and I will issue you a full refund
For the record, I have sold hundreds of these, and people have fitted them to the Mk1
& Mk2, Cooper S, Mini K, Mini Deluxe etc and this is the first complaint.
There is no flap for the ID Plate cut in the pad on the one i supply for two reasons,
1 I have found that the body plate is not always fitted in the same position,
2 not everyone wants this feature. however this is not a huge problem to overcome,
It requires three cuts with a Stanley knife in the position you require,
I estimate the time it would take would be 3 minutes all up.
John Smidt
PostPosted: Thu Aug 11, 2016 10:11 am
Hi John
Tell me is the wiper motor on a mk2 Cooper s in the same position as a mk 1
Sent from my HTC_PN071 using Tapatalk
1970 MK2 Cooper S
PostPosted: Thu Aug 11, 2016 4:22 pm
The Mini King
GundyGuy wrote:
Hi John
GundyGuy,
The Lucas 12AUW round body wiper motor on the MK II Cooper S was also used during the later stages of Mark 1 production so the answer to your question is yes and no.
The insulation we supply is meant to suit most situations but even the factory had subtle changes to this item over time. For example, some had a long slit behind the washer bottle so the bracket could be accessed, a wide slit in the middle to accommodate the speedo cable, a flap in front of the ID plate for those Mark 1’s that had a plate, a flap in front of the paint sticker on some Mark 2’s, etc.
This morning I have checked with several people who have used the mat in both Mark 1 and Mark 2 restorations. They tell me it fits well with a few minor alterations to suit their particular situation, as mentioned above. I will consider altering the design in future supplies so the mat has no wiper motor cut-out at all. It would come with an instruction sheet and cutting templates to suit both square and round bodied wiper motors.
Please confirm the item supplied is undamaged and I will send you a pre-paid envelope for its return. I’ll credit you the full amount for the purchase. I am more than happy to do this for any customer who is unhappy, for whatever reason.
John Smidt
PostPosted: Thu Aug 11, 2016 8:39 pm
Another master class in customer service from John. Information, offers of assistance, alternative solutions, possible future ways to improve the product. And an offer of a refund. Boom!
Sent from my Nexus 6P using Tapatalk
PostPosted: Thu Aug 11, 2016 10:10 pm
Yep,
Been spending my hard earned quite a bit with John lately - great service, advice and has parts that are hard to find.....
I did have to do slight mods to my new bulkhead felt a while ago but was not much hassle.
Cooper S Mk2
Cooper S Mk1
PostPosted: Fri Aug 12, 2016 5:53 am
BBY755 wrote:
Yep,
Can you show me a photo of your bulkhead felt fitted
1970 MK2 Cooper S
PostPosted: Fri Aug 12, 2016 6:03 am
John Smidt wrote:
GundyGuy wrote:
Hi John
GundyGuy,
John Smidt
Hi John
Mate i appreciate your offer of a refund but i would rather if you could supply a blank piece of material and i will cut one to suit
Thanks
GundyGuy
1970 MK2 Cooper S
PostPosted: Fri Aug 12, 2016 7:55 am
I have used this item also and apart from very minor alterations no problems fitting it. (Mk 1 with round body wiper motor)
I think if you were truly determined to make your own you would need to buy the vinyl and backing separately and glue it yourself.
At one stage I was considering doing this because (if you want to be really fussy) the original Australian ones from the period of my car had a finer grain in the vinyl.
PostPosted: Fri Aug 12, 2016 9:14 am
As you stated you fitted one to a MK 1. What alterations did you have to make
I have seen a photo of one that the cutout for the wiper motor is lower
The old one i took off my car had the wrong cutout as well and i could not work out why it sat too low on that side and i couldn't pull it up
1970 MK2 Cooper S
PostPosted: Fri Aug 12, 2016 10:01 am
The Mini King
Hi Philip,
You are correct when you say that the original material was different, yes it was a finer grain and was backed with
different material than anything I have been able to buy these days.
It becomes very difficult to reproduce some items, because the materials used 30 plus years ago is
is not always available now days. In some cases it can be reproduced but the cost v demand has to be considered
