It is currently Mon Jul 28, 2025 6:24 am
 Post subject: Re: front drum brakes.
PostPosted: Mon Jun 20, 2016 9:28 am
1071 S wrote:
".....Mine are fine, I have no problem even on long downhill runs. .."
Then you obviously drive conservatively..... I drove an 850 for years and though the brakes were fine..until I switched to discs.
Drums will stop every bit as well as discs ..once or maybe twice... Why do you think Jaguar (and BMC) went to discs in the first place... The Laws of Physics apply ..as the fluid heats up the brakes go away.. and discs are better at getting rid of the heat..
Keep in mind that most (all?) 850's had single leading shoes which will lower the braking performance. Unless you have a 1275 or a worked engine, I've found the drums to be more than enough, provided that the maintenance is kept up.
The biggest difference I found when going form well maintained drums to discs is that I don't need to do so much maintenance any more. I used to adjust my drums every few months to keep it pulling straight and keeping a good pedal height, now I just need to flush the fluid and adjust the rear shoes. I haven't noticed any major improvement in performance, but I generally don't brake hard time after time, which is where disc brake performance really shines.
PostPosted: Mon Jun 20, 2016 7:04 pm
Personally I think drums are a P.I.T.A although, they are all I've ever had. I'm not confident they'd stop me very effectively on the M1, but I'm all about "granny spec"!!
PostPosted: Thu Jun 23, 2016 6:04 pm
I've got standard drums all round on my 998 they are still more effective than my 80 series land cruiser cant afford disks or I would just from a maintenance perspective.
Sent from my ZTE T84 using Tapatalk
PostPosted: Thu Jun 23, 2016 8:58 pm
How would the brakes be improved if I fitted a set of finned alloy drums?
PostPosted: Thu Jun 23, 2016 9:54 pm
They will cool quicker, so less brake fade, but nothing compared to moving to discs. They're also lighter.
PostPosted: Fri Jun 24, 2016 7:08 am
Twin LS drums stop pretty well in road use. I found they are better with new drums and shoes from Karcraft than getting drums machined oversize and fitted with local re-bonded shoes.
IMO a main benefit of discs is their self-adjustment.
PostPosted: Sat Jun 25, 2016 10:15 pm
I got some mintex brakes shoes when I was in the UK last and they seemed to work better than standard shoes from Karcraft
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jun 28, 2016 3:31 pm
I saw the mintex shoes on the minispares website and thought that they might be a good option.
PostPosted: Thu Jun 30, 2016 5:29 am
I have heard of Kevlar brake shoes which work as good as disc brakes apparently. Although I have never seen them myself or used them. They were mentioned by Chris Ellis of Bundaburg.
"Let us remove your "SHORTS"
PostPosted: Thu Jun 30, 2016 7:27 am
If you are considering a set of discs now would be a good time to import, whilst the Oz$ = 55gbp or so.
PostPosted: Fri Jul 01, 2016 5:45 am
If I changed to cooper s discs would I have to change the brake pedal? If so where do I get one from?
PostPosted: Fri Jul 01, 2016 6:38 am
No it will work fine with the stock pedal. And master cylinder if it is 0.70" bore. You should change the rear wheel cylinders to 5/8" to prevent lockup during heavy braking.
PostPosted: Sat Jul 02, 2016 5:28 pm
Thanks Dr Mini. I was wondering if I needed to change the pedal.
