It is currently Mon Jul 28, 2025 9:39 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Apr 15, 2016 12:32 pm
mooman10_0 wrote:
So worth keeping on if already in there im guessing? Benefits?
Steve
If you have them already they are more reliable than the rubber cross universals, and they are easy to unbolt to get the driveshafts out if you need to. They are also nice and strong.
Pot joints are a smoother universal joint (constant-velocity) and don't need the larger bore diff side covers the hardy spicers do.
IMO:
Rubber cross joints - Use them if you have to
Hardy Spicer - Use them if you have them
Pot joints - best on a cost and performance basis
PostPosted: Fri Apr 15, 2016 12:36 pm
If you need to buy Hardy Spicers, the only cheap bit is the U/J itself.
Re the S side covers (which are getting scarcer), I can machine thick Oz made side covers to fit the S bushes (also expensive now) and seals.
PostPosted: Fri Apr 15, 2016 12:52 pm
i have plenty of "S" final drive covers here
& we also have plenty of the thicker std mini ones if you want the thick ones are much better to machine than the std ones,
lots of people don`t realize there are thick-wall mini final drive covers :-)
Matt
PostPosted: Fri Apr 15, 2016 2:08 pm
I swapped the rubber joints for the MS QL5000 conversion, which uses a conventional Hardy Spicer joint with needle bearings, fitted with 4 nylon cups. Not sure if MS still has them in stock.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Fri Apr 15, 2016 2:18 pm
They were NLA for a while Karcraft has them listed currently. p/no QL5000.
http://www.karcraft.com.au, ask for a catalog on pdf.
PostPosted: Fri Apr 15, 2016 3:06 pm
MKO as well - http://minikingdomonline.com.au/product ... type-pair/
PostPosted: Sat Apr 16, 2016 3:39 pm
Is this the same conversion even if you have drums on the front?
Sent from my SM-G900I using Tapatalk
PostPosted: Sat Apr 16, 2016 3:49 pm
Yes makes no difference, driveshafts are the same regardless of CV used.
Hardy Spicers fit on 850-Deluxe-Mini K driveshafts, length is slightly different to S ones but fit the same.
PostPosted: Sat Apr 16, 2016 4:48 pm
you can use Morris 1500 diff covers too. Just a little machine and works a treat.
PostPosted: Sun Apr 17, 2016 7:30 am
If your drive shaft ends are in reasonable condition I recommend looking at aluminium bearing housings, cheaper option too.
http://www.classicmotoring.net.au/cmos/ ... ts_id=1409
Mini's I grew up with
Slot car couch
PostPosted: Sun Apr 17, 2016 8:01 am
Those look good, I looked at getting them made locally a year or so ago but cost was not competitive with QL5000.
PostPosted: Tue Jun 14, 2016 4:49 pm
Just resurrecting this post.
Have had a scrounge in the shed spare part division, have found 2 complete pot joints and 2 drive shafts. What more do I need to convert over from rubber universal joints. Do I need to change the diff output shafts and the diff covers.
PostPosted: Tue Jun 14, 2016 5:07 pm
Diff output shafts are different. Pot joint ones have a circlip to hold the "pot" on the output shaft
http://www.minispares.com/product/Classic/DAM3114.aspx
Diff covers are the same
Make sure that the driveshafts you have match the pot joints. The pot joint driveshafts aren't compatible with the rubber uni or Hardy Spicer couplings. There should also be a long and short driveshaft
PostPosted: Tue Jun 14, 2016 8:14 pm
Matt
I certainly didn't. which part is thicker? The material atound where the seal goes?
PostPosted: Tue Jun 14, 2016 9:40 pm
The right one (off a rod change box) has thicker walls, both are "small bore" diff covers for rubber cross/pot joints
Users browsing this forum: Bing [Bot] and 91 guests
