MiniMat wrote:
I too have started this job. I didn’t find it too difficult just working along prizing the rubber into channel with a nylon trim tool and fingers. I sprayed a little lanolin into the channel too, which may have improved my chances. The vertical rivet holes don’t line up perfectly with the frame, but that’s minor.
On the top pivot point, there is a pressed rivet, should there be a metal washer or nylon washer between the door frame and quarter vent flange?
On mine there’s quite a gap and the quarter vent can move up and down at that point. I think it effects the operation of the window as it always binds on the lower rubber... help
Have also just replaced the rubber seal. Didn't have any problems with it either.
The rivet that acts as a hinge for the top pivot point 'should' have a nylon washer. Only one side of my car has a washer but on the other side, there was not much of a gap so I didn't bother replacing the rivet and washer.
I bought 2 rivets and nylon washers from Mini King recently but didn't use them. The rivet is part no DXR412 but the washer isn't shown in my parts book.
By the way, make sure the nyloc nut and nylon washers on the bottom pivot spindle are tightened enough to resist turning too easily, or the 1/4 vent will swing closed while driving.
Binding on the lower rubber edge is also an occasional problem too.
