It is currently Wed Jul 30, 2025 8:16 am
 Post subject: Re: Groovy cylinder
PostPosted: Sun Feb 28, 2016 9:16 pm
I lifted one out the other day without a head on, I just put the lift bracket on the 2 studs and screwed the head nuts right down. The studs are hi tensile, they won't bend. Well, mine didn't!
PostPosted: Mon Feb 29, 2016 7:26 am
Good qual welded chain might be safer for the home mech...tie downs are terrific but you often don't know what real rating you are getting "these days"...when in doubt double up your tie downs :idea:
PostPosted: Mon Feb 29, 2016 2:31 pm
Thanks guys,
Which is the best engine lifting bracket I can buy as don't have the means to make one at the moment?
Cooper S Mk2
Cooper S Mk1
PostPosted: Mon Feb 29, 2016 2:37 pm
I used one like this using the centre front head stud. It put the engine/remote gearbox at the right angle to get it out.
http://minisport.com.au/mini-moke-engin ... 2-required
PostPosted: Mon Feb 29, 2016 3:59 pm
Thanks,
Looks good and sounds like you used only 1 which makes sense. I don't want to strain my head studs with 2 pulling inwards as the head is off. Doc reckons OK to lift on exposed studs without the head on, and the engine will be lighter without the head!
Cooper S Mk2
Cooper S Mk1
PostPosted: Mon Feb 29, 2016 4:18 pm
You could always loosely bolt the head back on?
Users browsing this forum: goodie and 101 guests
