It is currently Thu Jul 31, 2025 7:53 pm
PostPosted: Thu Jan 28, 2016 9:28 pm
Yeah for sure.
Part of the reason for posting was to sanity check the plan I had and make sure others thought it made sense. And to see if others knew of a better solution. So what DM etc said suggests the idea is on the right track.
And then the Holden heater tap link you guys suggested provides a good starting point to getting it done.
The body is being dropped on the engine/subframe this weekend so in the weeks after that I'll plumb in all of this stuff. I'll post an update once done to show how it turned out. (Though it'll be a few months before it's registered and properly tested)
PostPosted: Fri Jan 29, 2016 9:55 am
MinisPlus
Not sure if this will help with this project, but there is a spacer with an outlet available so the on head tap can be retained if fitted.
http://www.minisplus.com.au/classic-mini/product/heater-tap-head-outlet-spacer-block
Works great when using a water heated/cooled manifold or for an aux radiator. If you want to turn of the rad you would need to add an inline tap.
How can it be rusty when it's covered in so much oil?
PostPosted: Fri Jan 29, 2016 11:13 am
That's a great idea. I was looking at doing something like this for my clubby. Using a 3 or 4 way remote valve will look ugly and have hoses running everywhere.
AKA - GTOGREEN1969
PostPosted: Fri Jan 29, 2016 12:19 pm
hi hear is a pic of my aux radiator setup. i put a 7'' inch thermo fan but so far i havnt needed to turn it on. on hot days 35 degrees plus i open the tap full.the other pic u can see the radiator though the grill .... Dave
PostPosted: Fri Jan 29, 2016 4:28 pm
Ooh Minimanic that looks like a pretty good solution that I didn't think of. It would work perfectly when the heater is off. I wonder would the heater be less effective if the water is constantly also going to the aux rad...since it is going through two parallel circuits...?
I've ordered the heater tap that Morris posted, but I'm tempted to first just run this spacer with the standard heater take off valve above it. Worst case scenario I make some changes in winter if the heater is not as effective.
The only other downside would be that I can't shut off the aux rad (for eg the first 15 mins of running on a cold winter morning). Again, I might use that spacer method anyway and then compare the warmup times in winter with the aux rad connected and then not connected and see if there is an issue.
GTO I agree on the ugly hose thing. I was going to try to route the hoses discretely but the engine bay is only small!
DM I reckon I will do a similar aux radiator setup to what you've done in terms of placement behind the grill.
Alright - we have a plan!
PostPosted: Fri Jan 29, 2016 6:05 pm
How about using this to plumb the heater outlet into?
I run a big alloy radiator with the heater outlet plumbed into the thermostat housing. No need to run an axilary radiator.
1963 Morris 850
PostPosted: Fri Jan 29, 2016 6:14 pm
Hey Mini, if I didn't want the extra cooling capacity that would be a great solution. Given the extra horsepower I'm making I do want to give myself a little extra cooling capacity.
I reckon I'll use that on my future warm 998cc though :)
Users browsing this forum: Bing [Bot] and 75 guests
