It is currently Thu Jun 26, 2025 11:55 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Apr 27, 2016 12:22 pm
I have a question.hope someone can answer...my vin tag says my chassis no is...021A2S2M104122 but on the radiator surround on the o/s guard it says...021A2V2M101588..Im confused but Ive just drilled the rivets out to take the vin plate off for painting and found the original colour underneath plate a crappy purple colour.Ive had the vin on the plate checked with mainroads and it isnt on any stolen or encumerence list and the car doesnt have any tell tale signs of accident damage on the left side so just wondering if anyone else has had this on their Leyland Mini its a 73 model.cheers in advance.
Sent from my SM-G900I using Tapatalk
PostPosted: Wed Apr 27, 2016 12:52 pm
Well the 2V means Van, so something funny is going on there..
PostPosted: Wed Apr 27, 2016 1:48 pm
All I can say is if it had been damaged and repaired by using a secondhand guard they did a great job welding it in.
PostPosted: Wed Apr 27, 2016 1:50 pm
Is there anything stamped into the firewall behind the master cylinders?
There should be a body stamping of M2 and 21 and a body number. This number may help you work out if just the inner guard was replaced or the entire front end and firewall and compliance plate. The body number is around 500 less than the cars chassis number.
PostPosted: Wed Apr 27, 2016 8:17 pm
The above information is as good as I could offer
The build name for your saloon should be 021A2S2M10 and the equivalent van would be 021A2V2M10
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Thu Jun 16, 2016 6:57 am
Thanks guys
PostPosted: Wed Dec 14, 2016 6:39 am
So how can I tell which year it was made, my ID plate below?
PostPosted: Wed Dec 14, 2016 6:50 am
June/July 1964 according to John Sneddons book
PostPosted: Wed Dec 14, 2016 7:06 am
Thanks, previous owners thought it was a 63, what identifies the year??
PostPosted: Wed Dec 14, 2016 7:10 am
The car number and engine give the date. The 8Y engine was Aussie assembled from February 64.
If you have the original windscreen wiper motor, distributor, etc these all have date stamps on them (normally a couple of months before the car was built)
You can get a copy here:
https://www.ebay.com.au/itm/262750754883
PostPosted: Thu Dec 15, 2016 5:42 am
Checked the wiper motor and you're spot on, May 64.
PostPosted: Mon Apr 09, 2018 2:10 pm
G'day John
Got your book Australian Mini & Moke.. Fantastic tool. It has helped me identify my 1971 Mk2 Cooper S.
VIN and engine numbers were a great help.
Is there a data base showing what colour a particular car was painted and what options it came with?
Michael
71 MKII Cooper S
PostPosted: Thu Apr 02, 2020 10:03 am
Hi John,
Might be a bit late for you but see attached. This is from my Mini Cooper 997. I think it was produced in 62 but first registered in 63. If you could confirm the build year for me, it would be greatly appreciuated!
PostPosted: Thu Apr 02, 2020 10:50 am
You can see where your car sits in the production timeline using the Cooper Register - viewtopic.php?f=47&t=91060
If it's OK we'll add your car's details in the next Register update. Can you confirm the trim colour?
PostPosted: Thu Apr 02, 2020 11:11 am
It was a light green colour (see attached - can be seen on the back seat).
