It is currently Fri Aug 01, 2025 12:23 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jul 29, 2014 10:50 pm
I picked up a WB02 sensor from Tech Edge a few years back, assembled and tested it and just never got around to fitting it up :)
Anyway, I've dug it up now, maybe I should get to it...
PostPosted: Wed Jul 30, 2014 4:10 pm
Webcon UK do a nice kit,
http://www.webcon.co.uk/shopdisplayprod ... d+Displays
PostPosted: Wed Jul 30, 2014 5:09 pm
I think the kits(like mine) are a bit of a legacy now.
There's a risk in constructing them without errors, and they're a little harder to mount up than a simple gauge and sensor. You've got to like building kits I guess :)
PostPosted: Mon Aug 25, 2014 1:09 am
Hey Doc,
Have been looking at setting up a portable gauge myself as I've never been confident at setting mixtures. What is a good air fuel ratio to aim for or does it vary as the rpm increases? I would assume you and most of us would run a 98 octain fuel in most road cars. Would it change the air/fuel ratio if a lesser octain fuel was used. Any info would be good.
Ian
PostPosted: Mon Aug 25, 2014 6:17 pm
I've got an AEM Wideband Uego gauge with Bosch sensor and this is my AFR
tickover 13:1
cruise 14-14.5:1
Accel 12.5:1
WOT 12.5-12.8:1
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Mon Aug 25, 2014 8:53 pm
Is richer the higher or lower number? i.e does the number increase or decrease as it gets richer?
PostPosted: Mon Aug 25, 2014 9:00 pm
12.5 is rich 14.7 is 'ideal'
It's easy once you know how.
PostPosted: Mon Aug 25, 2014 9:07 pm
It is normally referred to as A/F ratio (Air/Fuel ratio) so a 12/1 A/F ratio is 12 parts air to 1 part fuel (rich), whereas a 20/1 A/F is 20 parts air to 1 part fuel (lean)
Caleb
PostPosted: Mon Aug 25, 2014 10:32 pm
Hi
I have recently dug out my Innovate LC-1 wideband controller and have begun to tune my HS4 SU on my 1098.
I bought the Innovate tailpipe exhaust clamp but I was having trouble getting a steady reading with idle revs below 1000 rpm, as others have found.
So I decided to lengthen the exhaust clamp with a piece of 1/2 copper tube. I simply expanded the end, cut four slits in it with a hacksaw and hose clamped it to the end of the exhaust clamp. On the open end I expanded it a bit and but a flare on it ( I don't know it this makes any difference). I had to bend it a bit to match the exhaust pipe bend.
The results were very good, :D the readings are now stable way down as low as the car will idle (about 600 rpm).
Check out my video, idling about 900 rpm.
Caleb
PostPosted: Thu Aug 28, 2014 3:58 pm
How much accuracy do you lose with it stuck up the tail pipe vs sensor nearer to the engine?
PostPosted: Sat Aug 30, 2014 7:49 pm
If the reading is steady it should read the same.
