It is currently Sat Aug 02, 2025 8:23 pm
PostPosted: Sun Jul 20, 2014 5:36 pm
Shock absorbers are the same as brakes. You must always replace as an axle set, i.e. both sides at tha same time.
It would be potentially dangerous to do only one side, even if it is not leaking.
I checked the paperwork I kept for the yellow Koni's on my car; 80-1675 were for the front and 80-1794 rears.
PostPosted: Mon Jul 21, 2014 5:14 pm
Booked the car into link for tomorrow, would love to give it a go myself as it looks relatively cheap & simple to fix but need the car to drive to Lourne this Saturday, and I don't have the parts and a place to do it.
PostPosted: Fri Aug 29, 2014 12:10 am
How much did it end up costing for the install ?
Rover Mini Cooper 99'
Factory Standard.
PostPosted: Fri Aug 29, 2014 12:12 am
Also where did u get ur koni yellows _
Factory Standard.
PostPosted: Fri Aug 29, 2014 4:21 pm
Got the shocks from Topperformance in Vermont. Can't remember what I paid. I'll check when I get home.
PostPosted: Fri Aug 29, 2014 8:00 pm
Harley wrote:
Working on a budget, I'd simply replace the shocks with new ones of the same.
No real need to upgrade unless the car is lowered or driven quite hard.
Ho ho ho...upgrade from Konis???? Well I suppose it is possible...
Cheers, Ian
