It is currently Wed Jul 16, 2025 7:16 am
PostPosted: Tue Dec 24, 2013 4:16 pm
Hi
If any one would like some Cooper s Grill spacers drop me an email.
I have supplied some Ausmini members as well as my local mini friends and I will re do another run if there is any demand.
I think most of the info you need is on this topic site.
Regards Pete.
PostPosted: Tue Dec 31, 2013 6:38 am
I bought some of these from Firefirey - they work well, are exactly as described, and a he's a good person to deal with.
Geoff
PostPosted: Tue Jan 14, 2014 9:05 am
Got mine today, very good.
Actually whether you have an S/cooler or not the best feature I found is the fact that they are a tight fit on the screw so the screws always stay attached to the grille meaning you cant lose the screws.
I always found refitting the grille frustrating with the screws going everywhere but these keep them nice and straight and lined up with the holes when refitting the grill.
Phill
PostPosted: Tue Jan 14, 2014 7:36 pm
[quote="phillb"]Got mine today, very good.
Phill[/quote]
Hi Phill
Thanks for you comments and I'm glad your happy with the Grill Spacers.
I am making some more soon
Kind Regards Pete.
PostPosted: Mon Feb 24, 2014 12:55 pm
Hi
I now have some more Cooper S Grill spacers made.
Sorry if I have forgotten anybody who placed an order but I have misplaced my list of names and details
If you would like to drop me a PM I will be happy to supply you a set.
Regards Pete.
PostPosted: Tue Nov 14, 2017 8:01 am
Old thread, but I have a similar question. How many screws should there be holding the front grill on? and do you use the spacers even at the top 2 screws near the bonnet release?
cheers fellow mini peeps.
1970 Mk2 Cooper S
PostPosted: Tue Nov 14, 2017 9:47 am
Just checked my 68 build S.
My grille, as far as I can remember, only had 6 screws even though there are holes for 10 screws.
The bottom 2 holes in front of the oil cooler are not used and only 2 of the 3 holes on each side of the grille have screws. The middle holes don't appear to have ever been used.
All screws are fitted with spacers.
If you have an early MK1 S with the small vertical oil cooler then the bottom 2 screws are also used and there are no spacers.
The difference in screw length 1/2" vs 3/4", as per Doug's info, is probably the difference between cars with early and late oil coolers.
Hope this helps
RonR
68 build Mk1 Cooper S
PostPosted: Tue Nov 14, 2017 9:57 am
Thanks RonR,
Mine is a mid year 1970 Mk2, so I have the normal horizontal oil cooler.
1970 Mk2 Cooper S
PostPosted: Tue Nov 14, 2017 10:38 am
Mini parts book PUB1056M shows 6 spacers being used for the Cooper S grille, in the positions miniron has said above - 1 through each of the two the little extension pieces at the top, and 2 each side through the flat sheet behind the horizontal bars.
PostPosted: Tue Nov 14, 2017 10:56 am
Wonderful, thanks winabbey!
1970 Mk2 Cooper S
Users browsing this forum: Baidu [Spider] and 77 guests
