It is currently Sat Jul 26, 2025 6:29 pm
PostPosted: Fri Jan 21, 2011 1:37 pm
Not sure about that as the PO (between Doc and I) had a bit of a play. Right rear is a mess! I guess we'll see come this weekend.
PostPosted: Fri Jan 21, 2011 1:39 pm
Barney has a heap of neg camber on the rear and God knows what the toe-in there is.
I instructed the PO how to mod the fixed brackets, but he went a bit far!!! :P
Noooooo, I never touched it, as handling was OK (for a dry car):twisted:
PostPosted: Fri Jan 21, 2011 1:44 pm
A little too much toe-in me thinks. Will probably back the camber off a bit too. Front will be running about 1.5 deg negative with a smidge of toe out.
PostPosted: Fri Jan 21, 2011 2:04 pm
I am currently building the rear subframe for my van, and I will be making adjustable brackets out of the factory brackets, ill post some pics when there done.
Have a Nice Day.
PostPosted: Fri Jan 21, 2011 11:02 pm
Milatsmadmini
Any more on that doc?
PostPosted: Sat Jan 22, 2011 2:07 pm
1. Get wheel alignment at rear checked for EACH side.
2. Do some trigonometry to calculate how far up to move the hole.
3. Don't be surprised if the hole also needs moving forwards to eliminate toe-out. Many old crabbing Minis have this problem, even with no shims between the subby and bracket. A solution (if nothing seems bent) is to move the hole forward a few mm then add some shims for adjustment.
I have successfully fixed a few ausmini cars after they went to several well known and respected wheel aligners to stop rear end crabbing, and got the `sorry cannot fix' treatment.
PostPosted: Sat Jan 22, 2011 9:46 pm
I have also fitted the minispares brackets.... I had to file the holes to get the toe in and camber settings I wanted.
Whan't hard, just took a far bit of fiddling.
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
