ha ha... the brakes are there.. you just gotta push em!!!!
your used to having discs with a brake booster... you blow on the pedal and it'll lock up the wheels.
in a mini... the brakes will certainly stop you hard enough... but you gotta apply some force to em.
as to the clutch.. you should be able to drop the clutch and chirp the tyres.. I find that to be the easiest way to see if the clutch is ok.. although.. on a test drive some owners like to come with you
oil... hmmm well they say mini's leak oil. poeee says.. when it stops leaking oil.. you've run out.
it depends on how much it leaks.. mine, I'd say is leaking too much but its usually just seals or gaskets that need replacing.
put it this way... if you can get it past a roadworthy.. then its not leaking enough to worry about
...its leaking oil... and thats a good sign!
It lets me know that I havent run out yet.
-Tzi 4-9-04
