It is currently Sun Jul 27, 2025 3:55 pm
PostPosted: Thu Oct 26, 2006 9:36 pm
Also double check your wheel bearings, mine used to randomly pull hard to the left when braking, but only for a second, and sometimes it would be fine. Ended up being the RH wheel bearings were stuffed, and as far as I could tell it was because the LH caliper would grab fine but the RH would be out of action until it managed to readjust itself, or something like that, it was odd and nearly got me into trouble so I'm glad I sorted it.
I've also had similar problems, like real bad torque steer, because one of the steering arm bolts had sheered off :shock:
 Post subject: Re: Pulls to the left...
PostPosted: Thu Oct 26, 2006 10:51 pm
I want to have Al's babies
9YaTaH wrote:
EDIT: Mini Classic?? Disk brakes?? you could still have issues with a sticking caliper or undersize rotor.
Ed (for 9YaTaH :wink:): British Open Classic has 12'' rims with discs on the front. :)
PostPosted: Fri Oct 27, 2006 6:38 am
BohoMini wrote:
British Open Classic has 12'' Discs on the front. :)
[Edit for BoHo :lol: ] Man she must stop on a dime with all that 8.4 inch braking power....what size wheels are you running 12 inchers :P :)
