It is currently Wed Jun 25, 2025 5:28 am
PostPosted: Thu Jul 06, 2023 10:52 pm
remember they are connected by a small pipe, you still have to fill both tanks otherwise you will get one tank full and the other will be well less than half full until the liquid levels have enough time to equalize
PostPosted: Sun Jul 09, 2023 1:09 pm
MAXRACER72 wrote:
remember they are connected by a small pipe...
PostPosted: Sun Jul 09, 2023 5:01 pm
Just had the same issue as GuamMini - ran out of fuel, with LH tank empty and RH tank half-full but not flowing to LH side to equalize level.
Turned out to be a blocked breather hole on the top of LH tank. Fuel cap was non-vented so enough pressure built up inside the LH tank to stop fuel moving under gravity, from RH tank.
Timmy201 had already suggested this as a possibility but I thought was very unlikely, given the diameter of the breather tube.... apologies Tim, you were right.
