It is currently Sat Jun 28, 2025 7:13 pm
PostPosted: Sat May 15, 2021 5:29 pm
Bill B wrote:
... as per original mini K and, I think, S.
Same radiator used across the range - no difference for an S or a K.
PostPosted: Sat May 15, 2021 5:37 pm
They look very similar, although Newcell plates had different part numbers depending on which car they were fitted to- Yes?
PostPosted: Sun May 16, 2021 7:34 am
Except some went in the S (premium price) parts bin :!: :lol:
PostPosted: Sun May 16, 2021 7:41 am
Yes, there are different part numbers on the Newcell plate but at a point in time I understand the same radiator was fitted to all Mini models produced at that time. The S radiator wasn't different to a non-S radiator. Happy to be corrected though.
PostPosted: Mon May 17, 2021 12:45 pm
I was in the same situation when I restored my 850. I wanted to keep the original style tanks.
I was quoted around $650 for a good quality copper re core, or around $300 using a cheaper (Chinese) copper core.
In the end I got a new Minispares/Minisport radiator and had my local Radiator shop put my old tanks on it.
1970 MK II Cooper 'S' Supercharged 1310 with Megajolt.
1970 MK II Cooper 'S' Original resto project (SOLD)
1962 850 Original. (Under restoration)
1973 Leyland S (My first car. Now rebuilt, so my kids can learn how to drive a real car).
VMCI # 215.
PostPosted: Mon May 17, 2021 1:56 pm
That is an interesting option. Just have to consider the cost of a new radiator just for its core, then cost of swapping tanks and sides.
PostPosted: Tue May 18, 2021 9:13 am
Also check how many fins/inch the core has, some cheap UK ones only have 8. Not enough I found.
Oz radiators from 1964? on all have 16.
PostPosted: Tue May 18, 2021 10:59 am
The local shop has quoted $765 for a recore using a conventional 3-row core, or $565 using a 'modern' core with V-shaped fins.
Seems to me to be a bit steep. May be that I'm expecting too much but I bought a new 3-row radiator for $250 from Adrad about 4 years ago to go into another mini. Wanted to buy the same again - only problem was that Adrad never made 3-row mini radiators so the one I have was a 'mistake'.
Will try a few more suggested leads.
PostPosted: Wed Aug 11, 2021 5:50 pm
An update - just for anyone looking at recoring their radiator.
On a member's recommendation I eventually decided to use Phoenix Radiators in Wodonga. My old radiator had to be posted but that wasn't a big issue. Austpost was $19 each way and border closures at the time made driving risky.
Phoenix sourced a 3 row core but could only get a 13 gills/inch rather than the original 16 gills/inch. The actual tubes appear to be larger than the originals so it might compensate.
Clayton at Phoenix was good to deal with and seems to do a lot of classic cars. He replaced the original cracked filler neck with the same longer old style type and kept me up to date with progress.
I primered and painted it when I got it back, about 2 weeks later. All up it cost $550 plus freight. It isn't back in the car yet but looks a very neat and professional job. I know there are other options but I was interested to see whether repairing was an option today.
